2005 GMC Yukon XL VSS
jleinecke
Posted: November 23, 2005 at 9:46 PM / IP Logged
Hi,
I was wondering if any one could help me in locating the VSS for a 2005 GMC Yukon XL W/ Bose as well as the wiring diagram for same vehicle for a stereo/nav install.  Any help would be much appreciated.  Thank you
Jerry
mo12v
Posted: November 24, 2005 at 5:30 PM / IP Logged
The PCM (Powertrain Control Module) is in the left front of the engine compartment to the left of the fan shroud. The VSS wire is in the green plug, pin 50. ..... dk. GREEN / WHITE ..... 4K .......
Or @ instrument cluster, pin A4
Also found at the radio harness, on some models.
http://www.directechs.com/directwire/wire_body.asp?action=select&yr=5861&product=Audio
MO
Wednesday, May 29, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
