toyota sienna wiring
Welcome Guest :)
dentaol
Member -
Posted: January 29, 2006 at 12:05 AM / IP Logged
I need wiring diagram for my toyota sienna le 1999.
notoriouswill
Member -
Posted: January 29, 2006 at 1:20 PM / IP Logged
12volts | wht/red & wht/blue | + | ignition harness | Starter | red | + | ignition harness | Second Starter | | | | Ignition | BLACK / YELLOW | + | ignition harness | Second Ignition | BLACK/ red | + | ignition harness | Third Ignition | | | | Accessory | blue | + | not required for r-start | Second Accessory | | | | Keysense | | | | Power Lock | blue/white | - | passenger kick panel | Notes: they will test only by operating the key in the passenger door lock cylinder, not the rocker switch on the door itself. | Power Unlock | blue / YELLOW | - | passenger kick panel | Notes: they will test only by operating the key in the passenger door lock cylinder, not the rocker switch on the door itself. | Lock Motor | blue/red | | integration relay | Notes: the integration relay is at the bottom of the fusebox. | Unlock Motor | blue/black | | integration relay | Notes: the integration relay is at the bottom of the fusebox. | Parking Lights+ | green | | bottom of fuse box | Parking Lights- | GREEN/ orange | | combination switch harness | Hazards | | | | Turn Signal(L) | | | | Turn Signal(R) | | | | Reverse Light | | | | Door Trigger | RED / white | - | top right side of fuse box | Dome Supervision | RED / black | - | right side of fuse box | Trunk/Hatch Pin | GREEN/ black | - | top right side of fuse box | Hood Pin | black | - | at light or theft ECU | Notes: door lock ECU and theft ECU are in the center console. | Trunk/Hatch Release | GREEN/ YELLOW | - | switch on dash below radio | Notes: This is for the power sliding side door. | Power Sliding Door | | | | Factory Alarm Arm | arms with lock | | | Factory Alarm Disarm | disarms with unlock | | | Disarm No Unlock | blue | - | drivers kick panel | Tachometer | yellow, grn, or blue | ac | any ignition coil | Wait to start | | | | Brake Wire | GREEN / WHITE | + | brake switch or fuse box | Parking Brake | | | | Horn Trigger | GREEN/ black | - | steering column | Memory Seat 1 | | | | Memory Seat 2 | | | | Memory Seat 3 | | | | Interface Module: | Category:Immobilizer Bypass | Required:Yes | Type:Transponder | Part #: 555XW |
1 Memphis Mojo 15
1 Memphis 4000 watt amp
1 Memphis 75watt 4 channel amp
2 Memphis 6.5" MSQ's
dentaol
Member -
Posted: January 30, 2006 at 11:11 PM / IP Logged
thank you for you respons.
Sunday, June 9, 2024
• Copyright © 1999-2024 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
