2006 Hyundai Accent Alarm/Remote Start Wiring
hype6900
Member - Posts: 10
Posted: December 06, 2006 at 6:30 PM / IP Logged
I am looking for a wiring diagram for a 2006 Hyundai Accent. It is the four door sedan without power locks or windows. Any help would be appreciated. Thank you.
Twelvoltz
Platinum - Posts: 2,384
Posted: December 06, 2006 at 8:12 PM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - HYUNDAI / ACCENT / 2006 / Remote Start
[PRINT THIS PAGE]
12volts      green (40A), blue (30A)       +       ignition harness
Starter      white       +       ignition harness
Second Starter      N/A
Ignition      pink       +       ignition harness
Second Ignition      N/A
Third Ignition      N/A
Accessory      orange       +       ignition harness
Second Accessory      yellow       +       ignition harness
Keysense      blue       +       ign harn or BCM, 20 pin plug, pin 6
Notes: The BCM (Body Control Module) is to the right of the steering column.
Power Lock      blue       -       DKP or fuse box, 16 pin plug, pin 6
Notes: Also found yellow at the BCM, 24 pin plug, pin 13. The BCM (Body Control Module) is to the right of the steering column.
Power Unlock      yellow/black       -       DKP or fuse box, 16 pin plug, pin 16
Notes: Also found at the BCM, 24 pin plug, pin 1. The BCM (Body Control Module) is to the right of the steering column.
Lock Motor      gray       5wi      DKP or fuse box, 14 pin plug, pin 5
Unlock Motor      pink       5wi      driver kick, blue 42 pin plug, pin 1
Notes: Also found at the BCM, 24 pin plug, pin 18. The BCM (Body Control Module) is to the right of the steering column.
Parking Lights+      GREEN/ blk (L), yellow/blk (R)       +       DKP or fusebox, 14 pin plg, pins 9,8
Parking Lights-      red       -       switch or BCM, 20 pin plug, pin 12
Hazards      blue/black       -       BCM, 24 pin plug, pin 4
Turn Signal(L)      yellow/orange       +       turn signal switch
Turn Signal(R)      BROWN / orange       +       turn signal switch
Reverse Light      WHITE/ black       +       DKP or fuse box, 14 pin plug, pin 10
Door Trigger      green       -       driver kick, blue 42 pin plug, pin 2
Notes: Also found at the BCM, 20 pin plug, pin 2. The BCM (Body Control Module) is to the right of the steering column.
Dome Supervision      green       -       BCM, 24 pin plug, pin 12
Trunk/Hatch Pin      GREEN/ orange       -       driver kick, blue 42 pin plug, pin 3
Notes: Also found at the BCM, 20 pin plug, pin 10. The BCM (Body Control Module) is to the right of the steering column.
Hood Pin      brown       -       pin sw or BCM, 20 pin plug, pin 17
Trunk/Hatch Release      N/A
Power Sliding Door      N/A
Factory Alarm Arm      yellow/orange       -       driver kick, blue 42 pin plg, pin 35
Notes: Meter this wire while turning the key in the driver door key cylinder.
Also found at the BCM, 20 pin plug, pin 19. The BCM (Body Control Module) is to the right of the steering column.
Factory Alarm Disarm      WHITE/ black       -       driver kick, blue 42 pin plg, pin 33
Also found at the BCM, 20 pin plug, pin 4. The BCM (Body Control Module) is to the right of the steering column.
Disarm No Unlock      with ign, acc, and key sense
Tachometer      green       ac       L of fusebox, wht 42 pin plg, pin 32
Notes: Also found at the instrument cluster, 16 pin plug, pin 10.
Can also go to any fuel injector and use the wire that is NOT brown.
Wait to start      N/A
Brake Wire      green or orange       +       sw or fuse box, 14 pin plug, pin 11
Parking Brake      GREEN/ orange       -       sw or fuse box, 14 pin plug, pin 1
Horn Trigger      blue       -       horn switch
Memory Seat 1      N/A
Memory Seat 2      N/A
Memory Seat 3      N/A
Interface Module:      Category:
Immobilizer Bypass      Required:
No      Type:
N/A
Part #: N/A
Notes:
Smart Starter Kill Relays: Not Available
warning
Directed Electronics assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information.
hype6900
Member - Posts: 10
Posted: December 07, 2006 at 3:43 AM / IP Logged
Thank you for your help.
peddy
Posted: December 28, 2006 at 6:32 AM / IP Logged
woot thank you, this should be the same for the 2006 kia rio to. but test befor taping any thing =)
stealth94rttt
Posted: January 20, 2007 at 2:01 PM / IP Logged
Is there a neutral safety switch for this vehicle? If not what setups have you used to safely install an automatic start?
Thanks,
Josh
Saturday, June 1, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
