2005 hyundai elantra, remote start
sp4rky
Posted: December 12, 2006 at 9:06 PM / IP Logged
hi... i'm looking for hyundai elantra 2005 wiring for install a remote starter
Thank
shaggy12volt
Copper - Posts: 164
Posted: December 13, 2006 at 12:34 AM / IP Logged
WIRING INFORMATION - HYUNDAI / ELANTRA / 2005 / Remote Start
12volts      red and pink (common 40A)       +       ignition harness
Starter      white       +       ignition harness
Second Starter      N/A
Ignition      orange       +       ignition harness
Second Ignition      N/A
Third Ignition      N/A
Accessory      green       +       ignition harness
Second Accessory      yellow       +       ignition harness
Keysense      green or blue/orange       +       ign harn or ETACM, 16 pin plg, pin 2
Notes: The ETACM (Electronic Time and Alarm Control Module) is in the center console, behind the A/C controls.
Power Lock      pink       -       dr kick or ETACM, 20 pin plg, pin 20
Power Unlock      yellow/orange       -       dr kick or ETACM, 20 pin plg, pin 14
To unlock the driver door only, use blue (-) at the relay to the right of the fuse box, or at the ETACM, 16 pin plug, pin 1.
Lock Motor      gray       5wi      driver kick or door lock control mod
Notes: The door lock control module is in the center console, behind the A/C controls.
Unlock Motor      RED / orange       5wi      driver kick or relay R of fuse box
Parking Lights+      GREEN/ orange (L), pink (R)       +       fuse box, blk 14 pin plg, pins 8, 14
Parking Lights-      blue       -       switch or ETACM, 16 pin plug, pin 14
Hazards      green (only w/fac. alarm)       -       ETACM, 12 pin plug, pin 8
Turn Signal(L)      yellow/orange       +       turn signal switch
Turn Signal(R)      blue       +       turn signal switch
Reverse Light      brown       +       driver kick, 15 pin plug, pin 2
Door Trigger      yellow       -       dr kick or ETACM, 20 pin plg, pin 18
Dome Supervision      yellow or white       -       fusebox or ETACM, 20 pin plg, pin 11
Trunk/Hatch Pin      green to GREEN/ black       -       dr kick or ETACM, 20 pin plg, pin 10
Hood Pin      GREEN/ black       -       pin sw or ETACM, 12 pin plug, pin 7
Trunk/Hatch Release      N/A
Power Sliding Door      N/A
Factory Alarm Arm      factory remote only
Factory Alarm Disarm      factory remote only
Disarm No Unlock      with ign, acc, and key sense
Tachometer      blue       ac       PCM, 81 pin plug, pin 66 or cluster
Notes: The PCM (Powertrain Control Module) is above the driver kick panel.
Can also go to any fuel injector and use the wire that is NOT white.
Wait to start      N/A
Brake Wire      white       +       brake pedal switch or driver kick
Parking Brake      blue       -       parking brake switch or driver kick
Horn Trigger      red       -       horn switch
Memory Seat 1      N/A
Memory Seat 2      N/A
Memory Seat 3      N/A
Interface Module:      Category:
Immobilizer Bypass      Required:
Yes      Type:
Transponder
Part #: 556UW
Alternate Part1 #: DesignTech 20402
Alternate Part2 #: DesignTech 29402
Notes: Only Canadian models have the immobilizer system.
Smart Starter Kill Relays:      Relay Type:
Starter Relay      Location:
Engine compartment fusebox, Driver side
Part #: 6401A
The Shagmaster
1999 Chevy Suburban 15" lift sittn on 22's sets 7'5"
1992 Chevy Astro Van all Bagged out Dubbed THE SUICIDER
Installing for over 18 years Looking for empolyment NOW send PM for resum
Tuesday, May 28, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
