2006 Chevy Express stereo/alarm wiring
arkady3
Posted: January 12, 2007 at 1:31 PM / IP Logged
Hello,
I am trying to find wiring diagrams for stereo and alarm/remote start installation for Chevy Express 2006 awd
Thank you
Twelvoltz
Platinum - Posts: 2,384
Posted: January 22, 2007 at 7:29 AM / IP Logged
For Starter/Alarm DEI Lists:
DIRECTWIRE™ WIRING INFORMATION - CHEVROLET / EXPRESS VAN / 2006 / Remote Start
[PRINT THIS PAGE]
12volts RED / black (x2)(40A each)  +  ignition harness
Starter yellow  +  ignition harness
Second Starter N/A
Ignition pink  +  ignition harness
Second Ignition white  +  ignition harness
Third Ignition N/A
Accessory orange  +  ignition harness
Second Accessory brown  +  ignition harness
Keysense lt. green  -  ignition harness
Power Lock lt. blue  -  BCM, lt. blue plug, pin B5
Notes: The BCM (Body Control Module) is under the passenger side dash, behind the knee bolster.
Power Unlock white  -  BCM, lt. blue plug, pin B10
Lock Motor gray  5wi driver kick, door harness
Unlock Motor tan  5wi driver kick, door harness
Parking Lights+ brown  +  fuse box under driver seat
Parking Lights- BROWN / white  -  BCM, brown plug, pin B2
Hazards white  -  BCM, gray plug, pin A5
Turn Signal(L) lt. blue/white  +  turn signal switch
Turn Signal(R) dk. blue/white  +  turn signal switch
Reverse Light lt. green  +  BCM, black plug, pin F
Door Trigger see notes  -  BCM, lt. blue plug
Notes: The driver door trigger is tan in pin B4, the front passenger and rear cargo door trigger is lt. green in pin A5, and the rear doors or sliding doors trigger is yellow/black in pin A10. Use all three wires and diode isolate each.
Dome Supervision gray/black or dk. blue/white  +  BCM, black plug, pin E
Trunk/Hatch Pin common with door trigger wire
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm N/A
Factory Alarm Disarm N/A
Disarm No Unlock N/A
Tachometer white or purple  ac  PCM, green plug, pin 26
Notes: It is white on the 4.3L, and purple on the 4.8L, 5.3L, and 6.0L.
On diesel models, the tach wire is dk. blue/white at the ECM, 96 pin plug, pin 56.
The PCM (Powertrain Control Module) or ECM (Engine Control Module) is on the driver side fender.
Wait to start dk. blue  -  cluster or ECM, 58 pin plug, pin 16
Notes: The ECM (Engine Control Module) is on the driver side fender.
Brake Wire white  +  brake pedal switch
Parking Brake lt. blue  -  BCM, lt. blue plug, pin A7
Horn Trigger tan  -  BCM, gray plug, pin B9
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
2006 Chevy Express stereo/alarm wiring -- posted image.
Interface Module:Category:
Immobilizer Bypass
Required:
Yes
Type:
Passlock II
Part #: 1100F
Alternate Part1 #: 1100X
Alternate Part2 #: 556LW
Alternate Part3 #: 555LW
Alternate Part4 #: DesignTech 20402
Alternate Part5 #: DesignTech 29402
Notes: Standard on all models. The Passlock II wire colors are yellow, tan, and ORANGE / white (not used). When using the 1100F or 1100X, a software change to 1100GM is needed.
Combo Interface
Required:
Yes
Type:
Data Bus
Part #: 1700G
Alternate Part1 #: 457GW
Notes: Can use the 1700G or 457GW to bypass the Passlock II, but it will not control the door locks on this model year.
Door Lock Interface
Required:
No
Type:
N/A
Part #: N/A
Notes:
Smart Starter Kill Relays: Not Available
Directed Electronics assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information.
For Radio DEI Lists:
DIRECTWIRE™ WIRING INFORMATION - CHEVROLET / EXPRESS VAN / 2006 / Audio
[PRINT THIS PAGE]
Radio 12v RED / white  +  radio harness
Radio Ground BLACK/ white  -  radio harness
Radio Ignition (Class 2 Serial Data)
Radio Illumination N/A
Factory Amp Turn-on N/A
Power Antenna N/A
LF Speaker +/- dk. blue - lt. blue  +,- radio harness
RF Speaker +/- orange - dk. green  +,- radio harness
LR Speaker +/- tan - white  +,- radio harness
RR Speaker +/- tan - orange  +,- radio harness
Wednesday, May 29, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
