Rear View Camera, Shorten Feed Wire?
52-chebby
Member - Posts: 14
Posted: June 20, 2023 at 3:43 PM / IP Logged Link to Post Post Reply Quote 52-chebby
Is it possible to shorten (cut) and splice the feed wire to the camera on the back of my truck? I actually need to cut to pass wire through small hole but will shorten it at the same time.
audiokid1
Copper - Posts: 142
Posted: June 23, 2023 at 10:27 PM / IP Logged Link to Post Post Reply Quote audiokid1
Should not be a problem. Video, Shield/Drain, and Power are usually all separate....they can be shortened or extended.
52-chebby
Member - Posts: 14
Posted: June 24, 2023 at 8:13 AM / IP Logged Link to Post Post Reply Quote 52-chebby
Thank you for that, I sort of thought so but wanted to be sure.
audiokid1
Copper - Posts: 142
Posted: June 24, 2023 at 10:51 AM / IP Logged Link to Post Post Reply Quote audiokid1
What type of truck is it? YMM?
52-chebby
Member - Posts: 14
Posted: June 24, 2023 at 12:46 PM / IP Logged Link to Post Post Reply Quote 52-chebby
It's a 1952 Chevy pickup... Have a look at my electrical panel... Remember, this truck only had 5 fuses when new...Rear View Camera, Shorten Feed Wire? -- posted image.
Thanks for asking...
Thursday, May 23, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
