Problems wiring DVD player!
2004g35c
Posted: October 03, 2005 at 2:33 PM / IP Logged
I picked up a digital wheelz xenarc 700v screen and an Innovatek FD-7. I have the screen and DVD player both tapped to the cig. lighter on the passenger side. I used the radio shack wire taps to wire them. The mobile DVD player has many options for wiring. It comes w/ a cig lighter adapter to use, it also comes w/ a hard wiring kit and a regular in home adapter. The option I chose was the hard wire kit, obviously. The hard wire kit includes 4 wires...
1. red - Backup 12V
2. black - ground
3. yellow ACC 12V (assume its for the 'accessory' position when the key isnt turned completely)
4. blue - remote 12V
the yellow and blue wire run together, and the black and red run together with a large fuse inline on the red wire. I can again turn the dvd player on using the power button or remote, but again after 10-15 sec, it majically shuts off. The dvd player fits very snugly in to the upper glove cubby, i even removed it and tried but still the same thing.
Here's my problem: When the car starts, I turn on the dvd player. The DVD player loads the menu and plays the movie etc and works fine. After about 10-15 sec the power simply shuts off, no warning or anything. Shortly thereafter, the Xenarc screen senses no input and shuts off a few secs after that.
I tapped the cigarette lighter with the RED / black wire. I left the yellow wire untouched (as I will never be watching dvd's with the car off or in accessory) and the blue I ran a remote wire from my PAC audio unit. I thought maybe the yellow wire needs to be used as the red said (backup 12V), so i removed the red wire and instead used the yellow (ACC 12V). This time no power NOTHING, DVD player wouldnt even turn on. So i thought maybe I need to use a different cig. lighter and I moved the red BACKUP 12V over to the driver side. I then tapped that cig. lighter wire and the SAME problem, dvd player turns on for 10-15 sec then just shuts off. PLEEEASE HELP!! I have also read that I should NOT use the cig. lighter as a ground and tried a generic grounding point, but the screen would still shut off aft er 10-15 sec. I have searched online and asked many people, but STILL cannot figure this out. My only other options are:
1. try another video input device (from the house, which I know WONT shut off)
2. Try and use the cig lighter it came w/ as well and cut off cig. lighter head and wire using that, inserting an inline fuse on the RED / 12v wire.
I would PREFER to use existing wiring as its easier, but please gimme your input on what the problem could be!!
Modded 04' G35C loaded
19" Rays 19x9, 19x10 BFG TA KDW 2
GmTm01
Posted: October 20, 2005 at 10:31 AM / IP Logged
 wire it like it is a radio. boyh the red and yellow wire have to be used. try running it from the radio's power supply. if that dosen't fix it run a seprate power and back up supply.
Saturday, June 1, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
