how to hardwire monitor?
soufkackicustom
Member - Posts: 10
Posted: October 01, 2007 at 3:42 PM / IP Logged
I got a 10.4" tft lcd power acoustik monitor for free because it dosent have the plug to it.  So I need to hardwire it.  when I stripped the wire I have
bare wire
red  (my guess acc)
yellow (my guess 12+)
black (my guess )ground
brown (my guess a/v)
blue
white.
I only need ground,a/v1 in, and acc power.  my guess are from a monitor I hard wired b4
Platinum - Posts: 13,726
Posted: October 01, 2007 at 5:51 PM / IP Logged
Are any of the wires shielded?
Chances are the black is ground and red is power.  Most of these monitors have only switched power.  The other 4 wires are audio and video inputs.  You will have to figure out what is what after you get it turned on.
soufkackicustom
Member - Posts: 10
Posted: October 02, 2007 at 8:54 AM / IP Logged
none are shielded, the only one thats diffrent is the bare wire. Iam guessing its going to be the a/v ground
soufkackicustom
Member - Posts: 10
Posted: October 02, 2007 at 9:05 AM / IP Logged
ok after actually cutting the plug off, the bare wire is wrapped around a white wire, so thats my video signal. the brown,yellow,green,red ,black,white  and blue are single wire. one has to be power (red??) ground(black??) ones the dome light
gcorrea
Silver - Posts: 436
Posted: October 02, 2007 at 8:44 PM / IP Logged
open the monitor and look at the circuit board it might be labeled.
gcorrea
soufkackicustom
Member - Posts: 10
Posted: October 09, 2007 at 3:36 PM / IP Logged
well I hooked the red and black up, spliced in the a/v, got nothing.
gcorrea
Silver - Posts: 436
Posted: October 09, 2007 at 9:28 PM / IP Logged
get me a model number on the screen. i just did this to a monitor too since the only place to get the cable with the plug was from dei and they wanted like $30. i opened up the monitor and got the info from the board.
gcorrea
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
