audivox ccs 100 on a 2003 matrix
night scream
Posted: July 01, 2008 at 4:50 PM / IP Logged
Hi everyone:
 I bought this cruise control for my 2003 matrix Xr. and have installed the servo, found the vacuum line and did the thrthle linkage.
 Yet i can't find the dang Vss wire connection or the tach wire connector , since the instruction manuals i received where for cars up to 1995..  I have called audivox and all i've gotten was a where the wire is supposed to be and its color, same as with the tach wire..
 What i was told is the same as rostro says in their prduct area for my car:
2003  TOYOTA  COROLLA - MATRIX
CRUISE CONTROL
Part # 250-1176
Part # 250-1223
Control Lever: 250-3742 ,250-3421
Adapter: 250-4361
VSS Wire: LOCATION 2- 4 CONNECTOR ECM- 2ND CONNECTOR LEFT TO RIGHT
VSS Wire Color: VIOLET/WHITE
VSS Pulse: 4000
VSS Tach Wire: LOCATION 2- (E6) 31 PIN CONNECTOR OF ECM POSITION 5
Tach Signal Wire Color: BLACK
Brake Switch Positive: RED / WHITE
Brake Switch Negative: GREEN / WHITE
I have searched the entire area behind the glove box i even took pictures with my digital camera and i can't find either of the cables..  Besides that they say behind the glove box and behind it  besides there being some sort of canister for the a/c system , there are only 2 plugs, and upwards hidden under a small lid covered box are 3 plugs, but this box is upwards allmost reaching the air bag.
Can anyone please tell me where are those 2 wires i need to finally install the system and try it out.
I can post links to the pictures i took if needed
smcshark
Member - Posts: 34
Posted: July 03, 2008 at 11:54 AM / IP Logged
VSS can be found in the cluster wiring as well as tach
VSS white green at instrument cluster pin 18
Tach Balck pin 27 again at instument cluster
email me if you need pics
Automotive Electronic Specialist
night scream
Posted: July 03, 2008 at 6:45 PM / IP Logged
I found the ecm which is actually below the glove box as contrary  to what everything says that its behind the glove box.... and found the two cables i've been looking for so long.... which are the VSS and the tach source cables.
Now all i need is to connect them.. though.. i called audiovox to make sure it was the correct cables and though their answer was vague on the tach source wire.. they told me i had to check the tach source wire using a multimeter set on AC and to check if it had voltage while the car is in idle... anyone know if there's any truth to this??
Also i was told by a mechanic friend of mine that right in the engine compartment next to the throtle body the plug next to it is the VSS plug that sends the data to the ECM,, is this true, coudln't i just connect there, instead of being so close to the computer. Could the same be applied to the tach source wire i also need, couldn't i just connect form one of the distribuidor coils on top of the spark plugs and do the same thing?
Does anyone know about these? and if this can be done, does anyone know which of the 3 wires coming out of the vss plug i should use? Also if i can connect to the coils, since the matrix has 4 independent coils and each has 4 wires coming out of them, to which of these wires do i connect?
smcshark
Member - Posts: 34
Posted: July 04, 2008 at 8:16 AM / IP Logged
if you have found the ecm then you should use the wires you have instead of guessing. You really don't have to worry about the tach unless you have a standard trans. There is nothing to worry about hooking up so close to the computer. We do it all the time. simply put, once you have the vss and tach wires located you are good to go.
night scream
Posted: July 04, 2008 at 9:00 PM / IP Logged
Iconnected today all the wires and did a road test witht he cruise control hanging [in a way] and suprise it worked flawlessly fromt he first time, i did the tests 5 times setting the speed, decreasing and adding speed, so i came home and went into placing the cruise control where it will end up , so all i did was unplug the connector to re route the cables and then re-connected it , fixed up the wires a bit better.
But now for some reason after i placed it correctly and went to do a road test the module won't turn on?  I rechecked all the wires and still nothing...  Help, what did i do? or what do i do?
night scream
Posted: July 05, 2008 at 1:31 PM / IP Logged
Success!!!!!!
I found the problem is was a simple the power cable came loose, i tightend it and bingo flawlessly working!!
Thank you everyone for telling me  where the cables where.. though i was a bit scared i will admint connecting so close to the ecm.
