olds ciera switch wiring
Brandt
Posted: July 20, 2007 at 2:23 PM / IP Logged
Hello... Brandt here...
I am working to install Rostra's GlobalCruise on a 1990 Oldsmobile Cutlass Ciera and need to know the wiring connections for the switch.
I have the colors of white, blue, red, and grey at the switch.
Thanks, Brandt
ranger svo
Copper - Posts: 70
Posted: July 22, 2007 at 1:31 PM / IP Logged
The only problem is that those are not Rostra colors. Rostra would use Red, Brown, Green and Yellow. So I am guessing that you are trying to use a factory switch. If you can find me a schematic of the factory switch, I might be able to help.
The moving power of mathematical invention is not reasoning but imagination.
Augustus de Morgan
sparkie
Platinum - Posts: 2,061
Posted: July 22, 2007 at 7:42 PM / IP Logged
Those colors are not for a factory lever either. I suggest you get a Rostra cruise lever for the car.
sparky
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
