cruise control on 2007 silverado 3500hd
raulromo34
Member - Posts: 28
Posted: November 26, 2007 at 12:20 PM / IP Logged
Looking for wiring diagram for 2007 chevy silverado 3500 hd (i think its hd).  Installing an Audiovox cruise control unit, part no# 's  :    250-1316,    250-3421,   & 250-4379.  Audiovox said that we needed these parts.. any help will be apprieciated.  thanks Raul
football fanatic
raulromo34
Member - Posts: 28
Posted: November 28, 2007 at 12:08 PM / IP Logged
Has anyone installed a Cruise Control on one of these trucks????   If so what kind??  Audiovox?? etc.  any tips???  wiring etc. ??  any dificulties installing ??   can't seem to find  anyone who has done onetruck is a basic model.. no power locks, no power windows.  thanks.  Raul
football fanatic
Jopey
Posted: December 03, 2007 at 10:35 PM / IP Logged
What body do you have? Is it classic or new body. If it's a classic all you need is a handle!! It's already pre wired for cruise.. If nbs you will need all the parts that audiovox listed
raulromo34
Member - Posts: 28
Posted: December 04, 2007 at 11:32 AM / IP Logged
its the new body style. we just found the kit for it.   XK601-CRGM1A  i think its made by Rostra , but you need to call in...not on there webesite.   this is the only kit that will work..it has a separate arm that has to be cut out and installed.  this arm is mounted just behind the turn signal arm.  they make a few other kit (audiovox)...but customer reps and customer service are not on the same page.  reps say that a certain part is not a valid part number, but techs say it is...you need like a module, arm, and signal splitter...but we found out that that only works with the 1500 not the 3500hd model.
football fanatic
sparkie
Platinum - Posts: 2,061
Posted: December 13, 2007 at 7:52 PM / IP Logged
The XK601-CRGM1A isn't a Rostra piece. It will work and has different software for gas and diesel. It is designed to use a Rosta cruise switch. You can use either a dash switch, RF steering wheel mounted switch or column mounted switch.   Rostra does have a complete kit which includes an electronic cruise, but you need to follow their tech tip on installing it as it is done as a pedal pull set-up.
sparky
raulromo34
Member - Posts: 28
Posted: December 14, 2007 at 12:06 PM / IP Logged
you are correct, i found out that the interface is made by Data Start concepts.  I think the handle might be a universal by Rostra.
football fanatic
zziggy
Member - Posts: 20
Posted: December 18, 2007 at 3:10 PM / IP Logged
The XK601-CRGM1A is made by Trilogic and is marketed by numerous venders such as DEI, DataStart, Rostra, ByPassKits.com and many others.
You can use either the Rostra handles mentioned before or the SCS/Frigette handles.
Its not a hard installation and works exactly like the OE cruise, because it is, you're just adding buttons.
zziggy
Member - Posts: 20
Posted: December 18, 2007 at 3:16 PM / IP Logged
What you need for the New Body style is this XK601-CRGM1A and either a SCS/Frigette 5129 handle or a rostra handle. Many venders sell it,  ByPassKits.com, Xpresskit.com, DataStart.com.
Trying to make a pedal pull work on an electronic throttle truck isn't your best choice.
The Cruise is there, it just needs the remaining parts to work.
raulromo34
Member - Posts: 28
Posted: December 19, 2007 at 1:55 PM / IP Logged
got it already the xk601-crgm1a worked with a rostra handle.  (got it from datastart)- all electronic -no pedal pull needed.  thanks
football fanatic
raulromo34
Member - Posts: 28
Posted: December 19, 2007 at 2:00 PM / IP Logged
the one i got said data start on the instructions.  the handle i believe was by rostra and had to be cut out and added behind the turn signal switch.  because this is the 3500hd model the other O.E.M handles didn't work...some stuff was different, extra plug, extra pin...this was the only way to go.  works great.  it would have been nice to have it replace the turn signal switch like on the 1500 model, but even the hazard switch on the 3500hd is bigger.  thanks for the info.
football fanatic
Saturday, May 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
