ford carpet for enclosure, pics
Tegpilot
Copper - Posts: 93
Posted: March 11, 2008 at 8:13 PM / IP Logged
Hey guys, built this enclosure for my 04 f-150 extended. Anyone have any advice on obtaining oem type carpet? I have access to standard carpets, but am wanting to match as exactly as possible. Thanks. I'll post more pics when complete.
ford carpet for enclosure, pics -- posted image.
99 INTEGRA LS 4DR Forest Green.Alpine CDA9857 Deck. JBL 755.6 AMP, Kappa 50.7cs Front, Kappa 6x9's Rear, 4 JBL GTO804 subs
KarTuneMan
Platinum - Posts: 7,056
Posted: March 11, 2008 at 10:52 PM / IP Logged
You could come real close to OE color, but you don't want actual OE carpet.... it's heavily backed and would be
impossible to work with. It looks like you got the hang of glass.... why did you not use MDF?
Tegpilot
Copper - Posts: 93
Posted: March 12, 2008 at 11:16 AM / IP Logged
That's all I'm wanting is to find a color matched carpet, not necessarily the actual backed, molded carpet.
I needed more volume for those two 8's than I could squeeze out using just wood, so I glassed part of it.
Anybody else have any advice on the carpet?
davngr
Copper - Posts: 109
Posted: March 12, 2008 at 4:03 PM / IP Logged
i think he's asking why you dint use MDF instead of partical board for you enclosure.   try your local fabrics shop (key stone) they usually have a few different styles. another thing you could do if you have a spliter(used to slit leather) or konw where one is you could use, you can actually shave the backing right off any carpet makes it very easy to work with.
Tegpilot
Copper - Posts: 93
Posted: March 12, 2008 at 6:23 PM / IP Logged
Oh I got ya, it's mdf, I just really had to shave down the picture quality to get them low enough for upload.
joyrydn
Copper - Posts: 94
Posted: April 02, 2008 at 9:28 PM / IP Logged
your best bet it to check out some salvage yards to find an exact match on the carpet, or go online.  i have an 03 f150 ext. cab and i built a box for 2 12" subs and have then downfiring, they load off the floor for a harder hit, just had to take out the jack, 50" across box.  sounds awesome.  but try a yard to see if they have anything you could use hten it will be the same deal that you are looking for, but shave the backing off to make it thinner and more pliable. let me know if that helps.
Make it Euro'n!!!
evileagletalon
Copper - Posts: 65
Posted: April 04, 2008 at 8:00 PM / IP Logged
joyrydn, can you post up a few pics of your box for 2 12s? What 12's are you running?
Did you have to do a seat lift?
I have a friend that wants me to make a box for his ex cab f-150.
joyrydn
Copper - Posts: 94
Posted: April 05, 2008 at 2:58 PM / IP Logged
ya i can do that, im working on my headliner right now but i have to take pics of that anyway andi will post those as well. yes i have the seperate 2 seat lifts and the box is notched around that. so hopefully tonight or tomorrow afternoon i will have those pics up.
Make it Euro'n!!!
