How to strengthen joints
toolinmaine
Member - Posts: 26
Posted: January 29, 2006 at 12:32 PM / IP Logged
When you wrap the fleece around the MDF and staple it to the rabbit routing how do you strenghen the joint. It seems to me as though the fleece would only have like 1/2 inch to grab on to. Is that enough? Do you need to FG it inside too? How do you make the joint between the fiberglass and MDF as strong as possible?
eric anderson-nosredna cire
notoriouswill
Member - Posts: 32
Posted: January 29, 2006 at 1:08 PM / IP Logged
i will pour resin inside the box to strenghten the joints and where the fleece meets the mdf. As long as the resin seeps into the mdf it will be a strong joint. Hope this helps
1 Memphis Mojo 15
1 Memphis 4000 watt amp
1 Memphis 75watt 4 channel amp
2 Memphis 6.5" MSQ's
How to strengthen joints -- posted image.
jfunk06
Copper - Posts: 64
Posted: January 29, 2006 at 4:18 PM / IP Logged
Going with the post above, i lay more glass just in the corners.  Make like, say, 2in wide strips and just lay them in the corners(with resin ofcoarse) to attatch the mdf and glass together on the inside too.   Like filling cracks with caulk, but, with FG! How to strengthen joints -- posted image.
Govenor of Jimcinati
93' GMC Safari XT
toolinmaine
Member - Posts: 26
Posted: January 29, 2006 at 9:16 PM / IP Logged
Thanks guys.
Monday, February 16, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
