How much do you pay for resin
j_darling2007
Copper - Posts: 210
Posted: February 05, 2006 at 3:12 PM / IP Logged
i looked on US Compsite's web site and it showed around $55 per gallon of resin.  Is this about the going rate.  Is there anyone cheaper.  Where do you guys buy yours.
There are 3 kinds of people in the world, those who can count and those who can't
wickedcustoms
Member - Posts: 6
Posted: February 05, 2006 at 4:58 PM / IP Logged
Check at the home depot I bought some from there and it was around $20 Per Gallon plus hardner For the bondo brand. I would check there before I buy it any where else for $55 then have to pay shipping and handling.
chrisne77
Member - Posts: 13
Posted: February 06, 2006 at 11:24 AM / IP Logged
The 435 resin form U.S. Composites is $23.95. I used Bondo brand resin before I found this stuff. I will never go back to Bondo resin. The 435 wicks into the mat and fleece so much better. The mat from U.S. Composites is cheap for what you get also.
HottAccord
Silver - Posts: 247
Posted: February 06, 2006 at 11:32 AM / IP Logged
You're definitely better off buying from Home Depot or Lowes. By the the time you pay for shipping & that hazmat surcharge, youre gonna be paying a lot more. That $20 gallon Bondo brand resin does just fine..IMO How much do you pay for resin -- posted image.
Im a fiberglass whore!!
j_darling2007
Copper - Posts: 210
Posted: February 06, 2006 at 1:00 PM / IP Logged
Is the 435 resin any stronger than the bondo brand.
Also, about how much will I need?  I will be doing 2 kickpanels and 2 subwoofer boxes behind the wheelwells in a 95 cavalier.  About how much resin would each project take.  Also, which one would you guys do first.  This will be my first fiberglassing and I want to do the easiest on first for practice.
Thanks for the help, hopefully one day I will be able to pass it on.
jfunk06
Copper - Posts: 64
Posted: February 06, 2006 at 2:16 PM / IP Logged
Although a subwoofer box would probally be easier, i think the kickpanel would be best to start.  This is because of rhe size, and if you mess up, its a lot less materials you wasted!
Govenor of Jimcinati
93' GMC Safari XT
HottAccord
Silver - Posts: 247
Posted: February 06, 2006 at 3:30 PM / IP Logged
Just buy a gallon to be safe/economical. It makes no sense to have to keep running back to the store to buy smaller quarts.
deagle50ae
Member - Posts: 21
Posted: February 06, 2006 at 9:20 PM / IP Logged
my single sub box (about 1.2cubic feet) took an entire gallon and I had to quit early because I ran out (only 4 layers thick, instead of the 7 I was planning on)I'd say get two gallons. do your kick pannels and split the rest between the sub boxes to get them as strong as possible.
j_darling2007
Copper - Posts: 210
Posted: February 07, 2006 at 5:18 PM / IP Logged
Alright.  Thanks for the help.
Is USComposites about the best price for the mat.  Do I need 3/4, 1 1/2, or 2 oz. mat.  If I understand right, It really wouldn't matter, I would just have to do more layers with a lighter mat, right.  About how much would I need if I used the 2 oz. mat.  The roll is 50 in wide.  Like mentioned above, I will make 2 kicks and 2 sub boxes.
Thanks for all your help,  this is my first fiberglass project and I'm still learning.  Thanks for helping me.
djfearny2
Silver - Posts: 810
Posted: February 07, 2006 at 6:27 PM / IP Logged
First off all the reason you should by resin from us composites is becasue that stuff is fresh, and 2 it is a ten times better quality. the problem with the bondo brand is one you dont know how long it has sat around and 2 its crap left over resin. There is no hazmat fee on one gallon cans another place that sells resin and mat and all of that stuff is select products .com they are around the same price as us but it is airplane qaulity resin. if you want a good first experience spend a little more and get the good stuff as you will come to find out the materials make the project work. One of the things you will experience with that green shaded crap resin from lowes, homedepot, autozone, pepboys is the worst thing of all it hardens to quick. the reason it hardens fast is becuase the shelf life of it has passed. Yes resin has a shelf life. This is the time in which it will be the most productive. if resin gets old it will work but not very good and things like hardening to fast will mess you up. go to selectproducts.com or us composite I promise you You'll be happy.
dont take my word for it. Buy 1 gallon from us or select. than by a pint or whatever from lowes or one of them. Mix up 250 ml each brand in its own cup. use the right amount of harder then time it or better yet dont use that much use a little. same difference.
what you are looking for in resin is one that is redish in color that is the good qaulity stuff. the greenish color is crap stuff(bondo brand)
If you want to go cheep i understand but the outcome and work time will be dramatically affected and will give you a bad taste in your mouth. I know for fact no fiction that selectproducts.com sells more than 120 gollons of resin in one month. so there stuff is never sitting around But they buy it from composite one which is another leader in material like that. Do the right thing you will not be sorry.
Jon available by email anytime for assistance.
Jon
Installer/Help Technician
---coral springs florida---
Sunday, February 15, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
