paint and such
naptothed
Member - Posts: 9
Posted: February 17, 2006 at 7:00 AM / IP Logged
Hey I'm new to to "system" fiberglassing, and I was wondering if everyone one would post up there equipment for painting ( i.e. - brands of paint, guns, and the psi used ) there enclosures.  I hate painting with cans, and I own a compressor, so I'm looking for a cheap alternative that ya'll know works good.
Thanks in advance
naptothed
Member - Posts: 9
Posted: February 17, 2006 at 7:05 AM / IP Logged
Also, this may be an incredibly stupid question, but what exactly wet sanding?  Is that using say 1200 grit sand paper that's soaked in water to sand?  Can someone explain this entire process.
Thanks Again
psychographic
Member - Posts: 21
Posted: February 17, 2006 at 9:57 AM / IP Logged
I have too many spray guns, touch up guns and airbrushes to list. If all you are doing is painting small areas you don't neeed a great gun, spraying is all practice and learning how the product you are using sprays. Wet sanding is sanding with water to keep the paper from clogging.You do need paper made for this purpose.
Sessland
Copper - Posts: 58
Posted: February 17, 2006 at 10:28 AM / IP Logged
Most air tools (guns etc,.) will have an air consumption rate or requirement for that tool. This can vary quite a bit between brands/products. Make sure that your compressor can handle the cfm and you should be fine.
For example this Dual Action sander calls for:
Operating pressure: 90 PSI
Air consumption: 6.0 CFM
If your compressor can put out 6.0 CFM @ 90 PSI, then you should be able to run that tool no problems.
jlord16
Silver - Posts: 322
Posted: February 18, 2006 at 5:18 AM / IP Logged
The paint your using will specify the thinning and pressure required to properly spary the product
Clarion DB36MP
Infinity Kappa Perfect 10"
Respone 800w Mono
ALPINE MRP-F250
*Custom fabrications*
ragoal12
Copper - Posts: 135
Posted: February 20, 2006 at 12:11 AM / IP Logged
well ur looking for a cheap alternative to spray cans.. well there isn't one unless u like capreting your projects... u get what u pay for with spray guns.. some guns r no better than puff cans really... SATA is top of the line but not needed... and do u know how to mix paint? as this is often screwy and when not mixed right you have to strip your project and start over so you need to do some practicing before... would hate to see someone mess up a project after long hours of work...
just a note: most of the art in spraying is in your body work.. if its not smooth before u paint it won't be afterward.. prep work is more important than the actual painting process to me...
S.O.B custsoms.. South Omaha, Nebraska
bellsracer
Silver - Posts: 703
Posted: February 20, 2006 at 3:20 AM / IP Logged
Best type of guns to use are the HVLP type. For just your basic paint job, all you really need is a quart size HVLP. If you plan on graphics, add a detail HVLP to it. If your compressor isn't HVLP type, you can buy a gun that has the regulator on it, so you can use an HVLP gun on a regular compressor. Regular guns are fine too, but HVLP will let your paint come on smoother with a lot less overspray.
Ganbatte Ne!
Friday, February 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
