Fiberglass kick panels in F-150?
stormraider04
Copper - Posts: 91
Posted: May 14, 2006 at 5:14 PM / IP Logged
has anybody made kick panels for an f-150? i have a 2002 f-150 and i was thinking about doing some. but i wanted to see some pics on how they look. if you have done them does the e-brake get in the way at all? what do you do about it? thanks.
Platinum - Posts: 12,488
Posted: May 14, 2006 at 10:22 PM / IP Logged
If the vehicle has a parking brake that you push down on the driver's kick panel, your better off making door pods that are angled rather than kick panel pods. The main reason is for imaging reasons because you won't be able to angle the kick panel pods as much or as required for proper imaging. Using the door panels and fiberglassing them in would be a better option with more room to move and angle the speaker pod.
jt73
Copper - Posts: 81
Posted: May 20, 2006 at 8:39 AM / IP Logged
i built some for an 03 f-150...you have to move the e-brake or put it on an electronic activator to engage/disengage
https://i23.photobucket.com/albums/b383/jsntarrant/100_0942.jpg
https://i23.photobucket.com/albums/b383/jsntarrant/100_0951.jpg
Monday, February 23, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
