cutting a window to show amps
noobhemi
Member - Posts: 20
Posted: May 31, 2006 at 12:13 PM / IP Logged
Hey guys, im trying to cut out a square window out of 3/4 mdf to show an amp that will be underneath it. Im having a hell of a time trying to cut it out with my router...is it possible to cut out the window using a jig saw? Whats the easiest way to cut it out? Might be a little confsusing to understand but any help would be appreciated. Thanks
Just tryin' to learn...
grantd
Copper - Posts: 60
Posted: May 31, 2006 at 1:26 PM / IP Logged
A jig saw should work just fine for you to cut out a hole in the mdf. It's going to give you some trouble if you're trying to flushmount some plexi or something in there. The router in that case is used to make a lip for the plexi to sit on. Anything else just let us know.
boug0752
Copper - Posts: 73
Posted: May 31, 2006 at 2:18 PM / IP Logged
Use a jigsaw or I actually prefer a Rotozip to cut the hole out. Then use your router to make the lip for the plexi to sit on.
If your counting pennies and dimes then maybe you shouldn't be spending every penny and dime you have!!
noobhemi
Member - Posts: 20
Posted: May 31, 2006 at 4:06 PM / IP Logged
Im going to go with the rotozip..it seems like the easiest way. Thanks for all the help guys, i appreciate it.
sparkie
Platinum - Posts: 2,061
Posted: May 31, 2006 at 6:47 PM / IP Logged
Use a fence or guide for whatever tool you use. It will give you a straight cut.
sparky
boug0752
Copper - Posts: 73
Posted: May 31, 2006 at 7:30 PM / IP Logged
Sounds good man. Good luck. Lets us see what it looks like when your done...
juniorxs
Member - Posts: 26
Posted: June 03, 2006 at 11:41 AM / IP Logged
use some double sided tape to fix down some battens then run your router against them, as long as you fixed them down straight your hole will come out perfect.
tackbradley
Member - Posts: 16
Posted: June 03, 2006 at 9:50 PM / IP Logged
hey noobhemi, let us know how it works out! im curious about the same thing! good luck!
~Jason
(516) Drum Co.
noobhemi
Member - Posts: 20
Posted: June 04, 2006 at 1:43 PM / IP Logged
Well, its been slow... this is basically my first time working with all the tools im using (17 yrs old). So far so good though, i finished cutting out the wlindow. The rotozip helped A LOT! ill keep u guys informed and take some pics of my progress
noobhemi
Member - Posts: 20
Posted: June 04, 2006 at 3:26 PM / IP Logged
Well, here are some pics of my progress and my truck which i am making this amp rack for...
cutting a window to show amps -- posted image.cutting a window to show amps -- posted image.
Page of 3
