carbon fiber?
xTimx
Copper - Posts: 354
Posted: June 18, 2006 at 11:54 PM / IP Logged
i see lots of things being made of CF. i was just wondering how hard it is to work with it. has anyone done anything with it? is it anything like fiberglassing?
xTimx
mouglie
Member - Posts: 23
Posted: June 19, 2006 at 3:08 AM / IP Logged
kind of i would asume, but you use epoxy instead of resin which is a bit more pricey, and you have to sandwich the cloth with sheets of acetone (sp?)(plastic). I would make the project out of fiberglass and then lay one carbon fiber cloth ontop of it and so on...
i haven't done this before so i might be wrong...
I shall never outrun my guardian angel - again.
Melted Fabric
Silver - Posts: 509
Posted: June 19, 2006 at 12:36 PM / IP Logged
There are many ways to accomplish working with CarbonFiber.  If you want to save money, then yes, you can use all the fiberglass you want / need, then lay a layer or two of carbon fiber on top to have the "look," but if you are building something like a hood of a car and want it to be strong yet have lite weight, I would use all carbon fiber, yet the price can be expensive.
Currently, there is a bit of a shortage in the industry for carbon fiber
Do not panic...
read this recent article from Fibre Glast Carbon Fiber Shortage Update
I have not failed. I've just found 10,000 ways that won't work.
When you do not know what you are doing and what you are doing is the best -- that is inspiration.
djfearny2
Silver - Posts: 810
Posted: June 19, 2006 at 1:10 PM / IP Logged
yes it is basically like fiberglass however you either can use a celar casting resin or a 2 part epoxy to lay over the weeve and well sanding, buffing clear coating al these things have to be done instead of fiberglassing where you have many options on wether you want to paint or cover the item. with carbon fiber not only is it costly it does have its pains it can be very anoying but it can also look amazing so you have to take that into effect as well.
Jon
Installer/Help Technician
---coral springs florida---
Melted Fabric
Silver - Posts: 509
Posted: June 19, 2006 at 2:36 PM / IP Logged
Hehe, and that too, ....what he said.
auex
Platinum - Posts: 5,041
Posted: June 19, 2006 at 5:24 PM / IP Logged
To short on carbon fiber, switching to kevlar. Similiar look 1/2 the price.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Sunday, February 8, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
