hid fog problem '06 x5 3.0i
fussion_101
Posted: January 15, 2010 at 10:45 PM / IP Logged
After I wired everything up the....
DDM Digital HID's turned on.
Relay from the wiring harness started buzzing. I replaced the relay and buzzing stopped for the time being. Edit: Constant clicking from the relay is back...
Check fog lamps still comes up on the display.
Did I go wrong somewhere?
Driver side:
hid fog problem '06 x5 3.0i -- posted image.
Passenger side:
fussion_101
Posted: January 16, 2010 at 12:46 PM / IP Logged
Update: I removed the relay harness and installed the hid's again. Everything works as normal. No BOW light. No flickering that I can see during the day. I'll check again at night.
Any ideas on what the problem is when I use a relay harness? I definitely don't want to use the fogs without a failsafe. I replaced the relay with new ones twice. The ground is located at the factory NEG bolt used to jump start.
liquidaudio_ss
Member - Posts: 21
Posted: February 16, 2010 at 10:29 AM / IP Logged
your vehicle is all can-bus related and you need to make sure your kit can handle the can-bus signal
Liquid Audio Styling & Sound Ltd.
Red Deer, AB, Canada
403-352-2224
