2017 Ford F-150, Under Truck LED Wiring
thegreatgazoo
Posted: July 06, 2021 at 11:31 AM / IP Logged Link to Post Post Reply Quote thegreatgazoo
Hi I have a 2017 f150. I want to install running board lights. I need to find
1- right turn signal wire
2- left turn signal wire
3- courtesy light wire
4- running light wire
I was told if I pull off the passenger rear sill plate there is a wire harness in there that has everything I need does anyone have the wire colors for what I'm looking for?
Platinum - Posts: 13,674
Posted: July 06, 2021 at 4:13 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Regular Key or smart key?
Posted: July 06, 2021 at 4:16 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Regular key wiring follows. It may be the same for smart key. Use a meter to verify.
Parking Lights      blue/gray (F); blue/gray (R)      +      BCM in passenger kick, 22 pin plug (G), pin 3; 36 pin plug (C), pin 12      Directwire
Parking Lights -      gray      -      headlight switch, black 16 pin plug, pin 11           Notes
Parking Lights Interrupt      black/violet      cut      headlight switch, black 16 pin plug, pin 4           Notes
Hazards      brown      -      hazard switch or BCM in passenger kick, black 52 pin plug (B), pin 19
Turn Signal (Left)      blue/green (F); gray/orange (R)      +      BCM in passenger kick, 40 pin plug (F), pin 39; 52 pin plug (E), pin 26
Turn Signal (Right)      yellow/violet (F); green/orange (R)      +      BCM in passenger kick, 40 pin plug (F), pin 38; 52 pin plug (E), pin 52
Headlight      blue      -      headlight switch, black 16 pin plug, pin 12
AutoLights      violet      cut      headlight switch, black 16 pin plug, pin 13
Reverse Light      green/brown      +      driver kick or BCM in passenger kick, 36 pin plug (C), pin 11
Left Front Door Trigger      brown      - N.C.      driver kick, harness to rear or BCM in passenger kick, 52 pin plug (E), pin 33      Directwire
Right Front Door Trigger      white      - N.C.      BCM in passenger kick, 52 pin plug (E), pin 21
Left Rear Door Trigger      green      - N.C.      BCM in passenger kick, 52 pin plug (E), pin 46
Right Rear Door Trigger      yellow      - N.C.      BCM in passenger kick, 52 pin plug (E), pin 19
Dome Light      gray/violet      +      BCM in passenger kick, 36 pin plug (C), pin 13
thegreatgazoo
Posted: July 06, 2021 at 6:37 PM / IP Logged Link to Post Post Reply Quote thegreatgazoo
regular key
Ween
Platinum - Posts: 1,366
Posted: July 06, 2021 at 9:01 PM / IP Logged Link to Post Post Reply Quote Ween
Might be best to use the trailer wiring for the running board lights...left turn, right turn, park/tail. If wired to the BCM outputs, the BCM could see additional load as a fault and shut down those particular outputs. Do the instructions state power consumption for the various lights?
Thursday, May 23, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
