Dual Switch Plus Relays, Entry/Exit Lights, 1993 Jeep Cherokee
blaube
Member - Posts: 17
Posted: July 12, 2021 at 9:32 AM / IP Logged Link to Post Post Reply Quote blaube
I'm interested in lighting up my entry/exit to/from my Jeep.
I decided to add a light to my roof rack pointing to the ground that turns on when I open the door or via a switch in the dash.
Plus a light strip on the interior that turns on when I open the door or by a switch from the dash.
So, I want both lights to come on when the door opens or when I flip a switch in the dash for the perspective light. I don't know how to wire the relays for that configuration. I may decide to add a circuit that slowly dims the lights to off when the ignition is off.
Any suggestions?
blaube
Member - Posts: 17
Posted: July 13, 2021 at 8:31 AM / IP Logged Link to Post Post Reply Quote blaube
I guess I'll wire it all on a test bench and figure it out on my own.
Custom_Jim
Copper - Posts: 210
Posted: July 13, 2021 at 11:22 AM / IP Logged Link to Post Post Reply Quote Custom_Jim
Sometimes that's the best way to do things.
1968 Chevy II Nova Garage Find 2012
1973 Nova Custom
1974 Spirit of America Nova
1973 Nova Pro-Street
Platinum - Posts: 13,674
Posted: July 13, 2021 at 2:10 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Year and model of the jeep?
blaube
Member - Posts: 17
Posted: July 13, 2021 at 2:28 PM / IP Logged Link to Post Post Reply Quote blaube
It's a 93 Jeep Cherokee. For this project, it doesn't matter. I'm adding keyless entry, removing the factory dome light and replacing it with the strip lighting and external entry light for safety and visibility in these dark Alaskan winters.
Yes, on a test bench may be the best way to learn how to do it. But, the summers are short and I don't have much time to get the project done. That's why I asked for assistance here.
Posted: July 13, 2021 at 4:47 PM / IP Logged Link to Post Post Reply Quote i am an idiot
12 Volts      red      +      ignition harness
Ground      (chassis ground)
Starter      yellow/green      +      ignition harness
Ignition      blue      +      ignition harness
Accessory      violet      +      ignition harness
Power Lock      orange/violet      +      drivers kick panel
Power Unlock      pink/violet      +      same
Factory Alarm Arm      arms with lock
Factory Alarm Disarm      green/orange      -      drivers kick panel
Parking Lights      blue/red           drivers kick panel
Headlight      brown/black      +      left of steering col
Left Front Door Trigger      yellow      -      underdash light
Thursday, May 23, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
