If you wish to post a reply to this topic, you must first login.
If you are not already registered, you must first register.
Tuesday, May 5, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
I think I figured it out. The only way I can make it work is with 3 Relays.
You would need the Lights on Lights off before the Two that you would put on both sides.
What do you think. Will this work?
