If you wish to post a reply to this topic, you must first login.
If you are not already registered, you must first register.
Tuesday, May 5, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
The last pictures show the connections when switch is OFF and ON. In the diagrams,
the Switch is GREEN
The LED is YELLOW
The Trigger wire to the Relay is BLUE
Ground is BLACK.
RED 1 goes to the dash lights through a diode and resistor in series so they 1) lower the brightness of the LED, 2) block the full +12 VDC RED 2 from flowing badk theough RED 1 to the lights.
The resistor and diode connected to RED 1 are not shown.
I need to know the value of the resister to diminish the LEDs brightness to about 1/2 when the switch is off, and the number and orientation of the diode to keep the full voltage of RED 2 from flowing back to the lighting system.
When the switch is turned ON, RED 2 to RED 1 are connected, as are GROUND and TRIGGER.
Any help is appreciated. It's been years since i've done anything like this. I want to be able to see the indicators of the switches at night, but not at full brightness until they're turned on.
Then you everyone.
James
