Headlights On With Lock/Unlock, Welcome/Leave Home
accordcu2
Member - Posts: 7
Posted: March 30, 2024 at 9:22 AM / IP Logged Link to Post Post Reply Quote accordcu2
Hey all,
I am trying to setup a module that i can use to turn on headlights with lock and unlock so basically I have all things sorted out except one thing. I want the module to stop working if my headlight switch is set to OFF position, so basically my switch gives negative ground to 1 of the wire when its set to OFF and i wanna use that signal to turn off the module but i cannot figure that out. I can do that with 5 pin relay but that would mean relay will stay energised and will drain the battery. Anyone know any other way? Like a transistor or something?
Thanks in advance
Honda Accord
