ultra linear ul600hc
elmore4030
Member - Posts: 21
Posted: March 03, 2008 at 2:32 AM / IP Logged
I have a friend that has a Ultra Linear UL600HC that supposed to put out 3000watts,but I can'nt find no decent spec's on the amp but these                     2 x 300W RMS @ 4 Ohm Stereo
2 x 500W RMS @ 2 Ohm Stereo
2 x 1000W RMS @ 1 Ohm Stereo
2 x 1200W RMS @ 0.5 Ohm Stereo
1 x 3000W MAX @ 1 Ohm Bridged                 I find it hard to believe that this amp puts out even close to 3000watts it has a Unregulated  Power Supply and it is a A/B design and most A/B desighn amps are about 40% to 45% efficient ,some of the better one go up to around 60%.I could'nt even find what fuse size it takes.This may be a great amp ,I just have never heard of it.He had it hooked up to two Solo Baric L5 12'' dual 4 ohms bridged at one ohm .When I got in the car I was excepting it to rattle me to pieces,but I can say I was dissapointed.My two T110D2 hooked up to my RF-XC7 hit harder and sounded a lot cleaner.Maybe someone else that has this amp had better luck,all I can say if that was 3000watts it was a poor 300watts.
Pioneer DEH-P960MP+Multi-CD Player Rockfordfosgate 225.2
Rockfordfosgate T8004 Rockfordfosgate 2 T110D2 InFinity Reference Components 2 sets of 6000cs 2 sets 6800cs
n2audio
Copper - Posts: 95
Posted: March 03, 2008 at 1:16 PM / IP Logged
http://www.mmxpress.com/Ultra/images/600HC.jpg
It has 6x40A fuses.  I'm sure it produces some power, but 2400 bridged at 1 ohm seems pretty optimistic.  At 1 ohm I would probably try to set the gain for aroun 1500w (38v) and see what you get.
Bad settings can have a BIG effect on what you hear.
Wednesday, May 29, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
