a novice at amp and sub settings
drunknspike
Posted: August 21, 2008 at 4:20 PM / IP Logged
ive got my amp and sub wired up
im running it off a sony cdx f7500
http://www.sony.co.uk/product/ica-cd...TechnicalSpecs
ive got amp+sub wired to 2 ohm
sub
http://www.crutchfield.com/S-Bm5770M...x?i=500MRDM605
amp
http://www.ice-direct.com/cid/KRRRQH...-PALP_MRDM605/
as my head unit is 2v ive tried setting my amp gain to match as its a digital amp i can see what the gains are on the lcd but it doesent have a 2.0 setting only
0.1/0.2/0.3/0.4/0.5/0.7/1.0/1.5/2.5/4.0/8.0
ive set it to 2.5 as its the closest to 2v but isnt very loud (the subs hardley moving) the head unit bass is set to none eq off sub on full
amp bass eq off
lp filter 85 (theres no 80)
subsonic filter 15hz
lp slope 24db
can any one tell me how to get the bass up and the sub moving
thanx
drunknspike
Posted: August 21, 2008 at 4:27 PM / IP Logged
drunknspike
stevdart
Platinum - Posts: 5,816
Posted: August 21, 2008 at 10:22 PM / IP Logged
Start with reading the sticky subject above about how to set gains.  It doesn't matter that your head unit "is 2V" and it doesn't matter what numbers are etched around the gain dial.  And disregard the digital LCD display on the amp.
When you set the amp gain to match the deck output, you will be listening for a tone deviation in a controlled test.  Wherever you find that golden spot is where you leave the gain dial...no matter what corresponding voltage number is associated with the setting.
Otherwise, the settings you listed above look to be fine.
Sunday, June 9, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
