04 f 150 stereo acc wire
smarler
Posted: December 02, 2008 at 6:23 PM / IP Logged
I had my aftermarket head unit installed and working perfect. Then I went to hook some RCA's for my sub into the head unit. When doing so the headunit shutoff and wont turn back on. It only turns on while giving it constant 12volt power. I checked the fuses and all are good. Stuck at this point any help would be great. Basically no power is coming to the (red) acc wire unless tied with constant power or an alternate acc wire such as cigarette lighter
ckeeler
Gold - Posts: 1,461
Posted: December 02, 2008 at 6:45 PM / IP Logged
did you check all the fuse boxes or just 1? how did you test the fusees? sometimes they can be bad and its not visible to the eye.
Platinum - Posts: 13,674
Posted: December 02, 2008 at 7:00 PM / IP Logged
I vote for a blown fuse too.  I have no idea where they are, but as stated above, there is probably more than one fuse box in the vehicle.
ckeeler
Gold - Posts: 1,461
Posted: December 02, 2008 at 7:10 PM / IP Logged
ckeeler wrote:
fusees
^^haha, what the!!?
smarler
Posted: December 02, 2008 at 7:28 PM / IP Logged
Its for a 04 F150 checked the radio fuse and radio(start)fuse and also sub fuse all were visibly ok should I just replace those three fuses to start
smarler
Posted: December 02, 2008 at 7:32 PM / IP Logged
also the aftermarket wiring harness for my F150 came with a harness with two RCA's for the stock sub. However the pins dont match up with the stock sub amp harness. Only 1 of the two rca's match up to the harness and only one of the two blue (turn-on) wires match up to the harness any ideas or am I just missing something
xplorin16
Copper - Posts: 52
Posted: December 02, 2008 at 8:39 PM / IP Logged
The harness with the rca's coming off is for the premium sound packages.  Depending on the vehicle the pins needed would either be on the top row or bottom, they put both on there so they dont have to make 2 seperate harnesses.  Just hook up which ever side corresponds to your particular vehicle and youll be golden.
Advanced MECP
Wednesday, May 29, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
