keep blowing factory amp
winterdru
Posted: May 18, 2009 at 10:13 AM / IP Logged
I have a 01 grand am with a monsoon system. I have a aftermarket cd player(pioneer) with a amp and a sub. I have had no problems with it until a few weeks ago i blew my factory amp. I ordered one off of ebay and it worked for a week or two and did the exact same thing as the first one did when it blew. I dont see any burnt connections inside the amp like i did on the first one. Any suggestions on what could be causing the amp to blow?
vibrationcustum
Copper - Posts: 171
Posted: May 18, 2009 at 5:47 PM / IP Logged
i would just bypass and put you own in or just bypass it all together
Can't be loud then don't have it.
(power acoustik system)
Head unit- TID-896 7" TOUCHSCREEN
ovn1-5500d 09 and another one coming soon
4-12" mofos 12ft3 box to 40hz (wall)
2 batterys, 1 power
icearrow6
Copper - Posts: 497
Posted: May 18, 2009 at 6:53 PM / IP Logged
The "output" voltage from your aftermarket radio is too high for the factory radio.
Up to a few weeks ago your hearing was fine..then you played it louder and louder..until the factory stereo gave out.
What you need to do is either get a new aftermarket amp for your speakers ( which will need to be replaced soon too).
aznboi3644
Gold - Posts: 2,600
Posted: May 18, 2009 at 8:52 PM / IP Logged
Q- What would be causing the amp to blow??
A- You.
Custom Enclosure Design
Platinum - Posts: 13,726
Posted: May 18, 2009 at 9:16 PM / IP Logged
A- You.
Q: Did I laugh at that one?
A: Why yes I did.
Q: Did it make sense to me?
A: Why yes it did.
alaisneo
Member - Posts: 27
Posted: May 20, 2009 at 10:04 AM / IP Logged
You shout at every post man..cut it out..let other people answer
I love sound
lil evo
Copper - Posts: 61
Posted: May 20, 2009 at 1:15 PM / IP Logged
Monsoon systems suck. Bypass it, add an aftermarket 4ch and you're golden
Monday, May 4, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
