wiring head unit, amp, and woofer
ckwu
Posted: November 23, 2009 at 2:08 PM / IP Logged
I have a Kenwood KDC-MP232 headunit, Formula-X FX-450 800W amp, and Boss D10F woofer, try to find a way to connect them together. Really new to it and want to DIY it thanks for all the help.wiring head unit, amp, and woofer -- posted image.
Platinum - Posts: 13,726
Posted: November 23, 2009 at 2:52 PM / IP Logged
How about you start with the Radio first and see how that goes.  Go to your local stereo shop and purchase the appropriat wiring harness for your vehicle.  Connect the wires of the new radio to the same color wire of the harness.   Above of course assumes that you did not already hack the factory plug out of your vehicle.
ckwu
Posted: November 23, 2009 at 3:16 PM / IP Logged
oh, I have install a cheap Dual Headunit from bestbuy already! The main concerns is will they be compatible or how to wire them together
BTW I'm newbie to installing amp and woofer
Posted: November 23, 2009 at 4:44 PM / IP Logged
Does the radio have Preamp outputs?  Usually a pair or more of RCA jacks.  Some red and some white.  Does your radio have those?  Did you purchase a wiring kit for the amplifier?
ckwu
Posted: November 23, 2009 at 5:41 PM / IP Logged
only one pair of RCA jack and the amp have 4 channel input and 2 channel output, its a second hand amp and I have few rca cable and speaker wire laying around.
Posted: November 23, 2009 at 6:06 PM / IP Logged
Is the power wire you have run through the car already large enough to power 2 amplifiers?  The existing amplifier, is it a 1, 2 or 4 channel amp?  To what speakers is the existing amp connected?
ckwu
Posted: November 23, 2009 at 6:44 PM / IP Logged
no, the headunit is preamp with 2 rca output
Posted: November 23, 2009 at 7:14 PM / IP Logged
i am an idiot wrote:
(1) Is the power wire you have run through the car already large enough to power 2 amplifiers?   (2) The existing amplifier, is it a 1, 2 or 4 channel amp?   (3)  To what speakers is the existing amp connected?
Thursday, May 21, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
