subs humming when cars off
johnmz24
Member - Posts: 13
Posted: May 08, 2010 at 10:27 AM / IP Logged
hey guys, iv tried everything from re routing my ground wires to 3 diff locations and nothing seemed to work. Im getting a constant humm when my cars shut off and i have the radio on. it goes away tho when the cars on. any ideas? i have the rca ran thru the pass side and i tried a brand new pair and same thing. brand new 2 gauge wiring also. Its 2 kicker cvr 12's and a memphis 500 rms amp.
anonymous1
Copper - Posts: 151
Posted: May 08, 2010 at 11:21 AM / IP Logged
If the car is not running and the humm you hear isnt rf bleed-over, then the humm is coming from your HU or your amp switching amplifier section. (me thinkests)
Can you try grounding the shielding on the RCA cable at both ends and see if this eliminates the hum?
Try grounding to both the amp body and the vehicle chassis.
Do you have the gain up all the way on the amp? If it's set on 11, turn it down a bit.
I know just enough to be dangerous. VERY dangerous.
Platinum - Posts: 13,679
Posted: May 08, 2010 at 11:26 AM / IP Logged
The amp should be turning off when you turn the car off.  I would use a switched power source to supply remote turn on power to the amp.
anonymous1
Copper - Posts: 151
Posted: May 09, 2010 at 12:12 AM / IP Logged
Perhaps the OP could clarify what they mean by "off" and "on?"
Engine running vs ACC?
licto
Member - Posts: 42
Posted: May 09, 2010 at 12:29 AM / IP Logged
Get down to basics........
Gozinta.....  Gozouta........
Disconnect remote turn on and see if they still hum.........
Put remote turn on back to the amp and disconnect RCA inputs to amp.......  still huming??
Measure another amp of some kind with a MULTI meter on AC......  looking at inputs and outputs.  I have never done this, I am sure most of the guys here have looked at them with meters and oscopes......  but its a cheap way to pick up some experience with what type of voltage is going in and what you can expect out or a working or not so working amp.
What should be where and when depending on the state of the system......  on or off.
Good ol poking around.
johnmz24
Member - Posts: 13
Posted: May 09, 2010 at 10:59 AM / IP Logged
its when i have it on acc, i took the rca off n it stopped. i also grounded it on the back of the headunit and the amp but still hums. Can it be a bad amp? My old headunit did the same thing and from the hum thats why i bought this new kenwood but its still there so im thinking maybe its the amp.
licto
Member - Posts: 42
Posted: May 09, 2010 at 6:10 PM / IP Logged
So many ways to test......  but I am thinking you understand pieces and parts......
If you disconnect the RCA's from AMP.....  it goes away.  Well you are on the right track but I am think NO.....  not a bad amp.  It means you are drving something into the amp and it is putting it out the other side.  Sure, there may be some type of issue with the amp, but I wouldnt go that far yet.  Get an IPOD, jack into the sub with a patch cord and turn it up a little.....  any hum still??  Or just some good bass.......
Or, get a batt, head unit of some kind, yank the amp and set it up in the garage and do a test or two......  no hum.....  good amp.
My understanding of a ground loop is that one end of the electronics is at a different potential than the other end.  So ground at the head unit is different than ground at the amp.  Ground loops have both an AC and DC element usually..........
I would get a mutlimeter and take a look by measuring with DC and AC between the two ground points......  if you get a reading......  that may be an issue.
Its like having a concrete floor in the back of the house that is not level with the concrete in the front of the house.  And you are trying to set up bunk beds......
Sunday, June 16, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
