dvc sub 4 channel amp
87pontiac
Member - Posts: 31
Posted: May 04, 2013 at 1:05 PM / IP Logged
Is it somewhat alright to connect a 4 channel amp to a 4 ohm dvc sub by splitting the LEFT rca into 2 (Y adapter) and connecting it to channels 1 and 2 on amp 1 and splitting the RIGHT rca into 2 (Y adapter) and connecting it channels 1 and 2 on amp 2 (another 4 channel amp). Set gains using VOM ( no scope available), each coil on each sub would get the exact same signal (mono) Im waiting for 2 mono amps, so in the meantime, i want use what i already have. Both amps (4 channels each) are rated at 150w x 2 @ 4 ohms in bridged mode. This way each sub will get 300 watts.
I know not typical hook up, but, any advice would be appreciated.
Ron
2001 Hyundai Accent
Canada
2 Dual xpa 6100
1 Clarion apx 200.2
Pioneer deh 6300ub
DYohn
Platinum - Posts: 10,741
Posted: May 04, 2013 at 6:48 PM / IP Logged
Sure, you can do that.
87pontiac
Member - Posts: 31
Posted: May 04, 2013 at 8:50 PM / IP Logged
Thanks for the quick response, I appreciate it.
87pontiac
Member - Posts: 31
Posted: May 04, 2013 at 8:57 PM / IP Logged
I have a set of Pyle subwoofers, 15" dvc 4 Ohm, I can't seem to find the TS parameters.... Anywhere, not even from Pyle, PLPW15D if it helps. Need to know this info for enclosure size. Please help!!!!!
haemphyst
Platinum - Posts: 5,059
Posted: May 05, 2013 at 8:23 AM / IP Logged
I didn't want to be the one to actually SAY it...
You'll have to spec them out yourself, sadly.
87pontiac
Member - Posts: 31
Posted: May 06, 2013 at 5:44 PM / IP Logged
Sad but true, emailing Pyle was pointless, calling was a joke, so I took the model closest to it and half ass'd it. Pretty sad when a company doesn't know it's own product!!!!lol!!!!!!
Saturday, April 25, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
