2011 Chevy Volt Radio Wiring?
Mja1962
Copper - Posts: 119
Posted: December 05, 2016 at 3:21 PM / IP Logged Link to Post Post Reply Quote Mja1962
Hello,
Can anyone provide me with a radio wiring guide for a 2011 Chevy Volt?
Any assistance would be appreciated.
Thank you,
Michael
Platinum - Posts: 13,725
Posted: December 05, 2016 at 5:56 PM / IP Logged Link to Post Post Reply Quote i am an idiot
What are you trying to do?
Posted: December 05, 2016 at 6:03 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Speaker Audio
     Wire Color     Plug/Pin #     Note     Picture
Speaker 1 Front Left (+)     LIGHT BLUE     2
Speaker 1 Front Left (-)     BROWN / LIGHTBLUE     1
Speaker 1 Front Right (+)     YELLOW     2
Speaker 1 Front Right (-)     BROWN / YELLOW     1
Speaker 1 Rear Left (+)     LIGHT GREEN     2
Speaker 1 Rear Left (-)     BROWN / LIGHT GREEN     1
Speaker 1 Rear Right (+)     WHITE     2
Speaker 1 Rear Right (-)     WHITE/ BROWN     1
Tweeter Front Left (+)     YELLOW/LIGHT BLUE     2
Tweeter Front Left (-)     YELLOW/GRAY     1
Tweeter Front Right (+)     BROWN / LIGHT GREEN     2
Tweeter Front Right (-)     VIOLET/BROWN     1
Subwoofer 1 (+)     LIGHT BLUE/GRAY     B
Subwoofer 1 (-)     LIGHT GREEN/ BLACK     A
Amplifier Fit Information
     New Column
Full Range Amplifier     LOCATED ON TOP OF THE SUBWOOFER ENCLOSURE UNDER THE REAR COMPARTMENT FLOOR BEHIND REAR SEATS
Note
Posted: December 05, 2016 at 6:11 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Head Unit Power
     Wire Color     Polarity     Location     Plug/Pin#     Note     Picture
Battery     RED / YELLOW     (+)     RADIO HARNESS     X1-44
Ground     BLACK     (-)     RADIO HARNESS     X1-38
Amplifier Turn-On     LIGHT GREEN/ YELLOW     (+)     RADIO HARNESS     X1-43
Posted: December 05, 2016 at 6:12 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Amplifier Power
     Wire Color     Polarity     Location     Plug/Pin #     Note     Picture
Battery     RED / BROWN     (+)     AMPLIFIER HARNESS     X1-4
Ground     BLACK     (-)     AMPLIFIER HARNESS     X1-8
Amp Turn-On     LIGHT GREEN/ YELLOW     (+)     AMPLIFIER HARNESS     X2-14
Amp Mute     VIOLET/LIGHT BLUE     (+)     AMPLIFIER HARNESS     X2-12
Amplifier Audio
Speaker 1 Front Left (+)     LIGHT BLUE     X2-1
Speaker 1 Front Left (-)     BROWN / LIGHT/BLUE     X2-9
Speaker 1 FR +     YELLOW     X2-2
Speaker 1 FR -     BROWN / YELLOW     X2-3
Speaker 1 RL +     LIGHT GREEN     X2-5
Speaker 1 RL -     BROWN / LIGHT GREEN     X2-4
Speaker 1 RR +     WHITE     X2-7
Speaker 1 RR -     WHITE/ BROWN     X2-6
Tweeter FL +     YELLOW/LIGHT BLUE     X1-1
Tweeter FL -     YELLOW/GRAY     X1-5
Tweeter FR +     BROWN / LIGHT GREEN     X2-8
Tweeter FR -     VIOLET/BROWN     X2-16
Subwoofer 1 +     LIGHT BLUE/GRAY     X1-6
Subwoofer 1 -     LIGHT GREEN/ BLACK     X1-2
Mja1962
Copper - Posts: 119
Posted: December 05, 2016 at 6:13 PM / IP Logged Link to Post Post Reply Quote Mja1962
Hello,
I would like to replace the factory radio in a 2011 Chevy Volt. Would anyone know if a kit such as the Axxess LC-GMRC-044 is compatible with the Volt? It's not officially listed as a supported vehicle, but then again, nobody seems to have anything for this car, as far as I can tell. I'm wondering if it's just the case that there weren't enough of the Volts made to justify the R&D, and perhaps this kit (or some other) would actually be compatible. Besides a trial-and-error approach, does anyone have any suggestions?
Thanks in advance,
Michael
wisco_install91
Posted: December 05, 2016 at 10:20 PM / IP Logged Link to Post Post Reply Quote wisco_install91
Does not look like Metra or PAC makes anything for this car yet.
Tell me again about your 5,000 watt amp you got for $99.00
Mja1962
Copper - Posts: 119
Posted: December 05, 2016 at 11:11 PM / IP Logged Link to Post Post Reply Quote Mja1962
Hi,
Thanks for the information you posted.
I am trying to install a Pioneer SPH-DA120 radio in a 2011 Volt. I realize that because the climate controls are integrated into the display, I'm going to have to keep the factory radio connected, even if I do manage to install the Pioneer unit. I have already relocated the factory display, and also separated the Pioneer's display from the enclosure so that I can mount it where the factory display was.
DYohn
Platinum - Posts: 10,741
Posted: December 15, 2016 at 2:05 PM / IP Logged Link to Post Post Reply Quote DYohn
Replacing the factory radio in a Volt is no simple matter as it is integrated into the vehicle information system. I would very much recommend you do not try to remove any of the OEM electronics in that vehicle.
Mja1962
Copper - Posts: 119
Posted: December 17, 2016 at 11:36 AM / IP Logged Link to Post Post Reply Quote Mja1962
Hello again,
I would like to install an aftermarket radio in my 2011 Chevy Volt. Unfortunately, the Volt's factory radio is very tightly integrated with the climate control system, and is also tied into the vehicle's warning chimes and alert sounds, so completely removing the factory radio is not feasible.
What I'd like to know is: how do I properly connect the aftermarket radio's speaker outputs to the vehicle while keeping the existing radio connections intact? (I am asking about the what the schematic should look like, not about making the actual connections. Also, I am experienced at soldering). Will I need resistors, diodes, or some other device to prevent any damage to the system? There are four pairs of wires coming from each of the radios, and I know the polarity of each wire, so I won't have any problems with phasing, but I assume that simply connecting the speaker wires from the aftermarket radio in parallel to the factory radio's outputs is not a good idea.
In summary, I plan to use all of the features of the aftermarket radio (music/navigation/cell phone integration). The factory radio will not be used to play music, it will only produce chimes and alerts, and both systems may produce sound simultaneously. Both units feed into the factory amplifier; I would expect to make my connections ahead of the amp.
Thanks in advance for any assistance.
Michael
Monday, March 2, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
