Dual 1 ohm voice coils
adam b
Posted: January 30, 2017 at 8:52 PM / IP Logged Link to Post Post Reply Quote adam b
I have 2 12 inch kickers that are dual 1ohm vcs. Right now they are hooked to a 1 ohm stable Memphis power reference amp that's 1000 watts. I would like to install my JL audio that's 1200 watts but at 2 ohms. I can wire each sub seperate to 2 ohms. My amp is a mono block but has 2 speaker connections. If I wire the subs individually to 2 ohms will it remain a 2 ohm load once I hook them to my amp? I've heard there's a way but really don't trust who I heard it from lol. Can someone please help me?
Adam B
the12volt
Administrator - Posts: 3,959
Posted: January 30, 2017 at 9:04 PM / IP Logged Link to Post Post Reply Quote the12volt
No, it will be a 1 ohm load at the amp. Your only other option is to wire all four coils in series for a 4 ohm load.
Dual 1 ohm voice coils -- posted image. the12volt • Support the12volt.com
adam b
Posted: January 30, 2017 at 9:07 PM / IP Logged Link to Post Post Reply Quote adam b
That sucks cuz it's only 600 watts at a 4 ohm load. I've also heard of people running 1 ohm loads on JL Amps without problems. What do you think?
Adam B
the12volt
Posted: January 30, 2017 at 9:19 PM / IP Logged Link to Post Post Reply Quote the12volt
The difference you'll hear between 600 and 1000 watts is minimal. I'd try it wired at 4 ohms and give it an honest listen before deciding which amp/set-up I liked best, but I'd stay away from running an amp at a lower impedance than its rated.
adam b
Posted: January 30, 2017 at 11:34 PM / IP Logged Link to Post Post Reply Quote adam b
Awesome! Thanks for the input and I'll let you know when I get it hooked up.
Adam B
Monday, March 2, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
