2006 Chevy Uplander Radio Replacement
charmoniii
Posted: May 21, 2018 at 11:08 AM / IP Logged Link to Post Post Reply Quote charmoniii
I have an OEM radio that I am wanting to replace. The part number is 15224733. The issue is that it has two wiring harnesses connected to it. One obviously is the typical 24-pin connector, however, the other one is an 8-pin connector and it is labeled radio. What could this 8-pin connector be? This vehicle also has a rear entertainment system.
In addition, does anyone have a radio wiring harness pinout for this vehicle?
charmoniii
Posted: May 21, 2018 at 2:42 PM / IP Logged Link to Post Post Reply Quote charmoniii
A correction -- it is not an 8-pin connector. It is a 12-pin connector. I believe that that is for the onstar, which I do not use anyway.
charmoniii
Posted: May 23, 2018 at 11:10 PM / IP Logged Link to Post Post Reply Quote charmoniii
I had to pull the aftermarket radio out and reinstall the OEM GM radio because on day two my uplander began showing the dreaded "service theft system" warning light. I had used a Scosche GM2000sw interface module (which interestingly does not show up on the Scosche website). That is the only time that this code has ever been displayed in this vehicle.
Wednesday, May 29, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
