Noob, Rockford P6001 Amp, Ohms and Subs
spirox
Posted: June 07, 2019 at 2:03 PM / IP Logged Link to Post Post Reply Quote spirox
Hi Guys
i'm a total noob to this and have a query regarding an install of 3 subs into my 1969 VW Beetle
so the hardware that hi have is
a Rockford Fosgate P6001, link below for illustration
https://www.crutchfield.com/S-VRCgnsUcqKL/p_575P6001/Rockford-Fosgate-Punch-P6001.html
the amp has a power output of
300 x 1 at 4ohm
600 x 1 at 2ohm
the problem
i have 3 Subs that i would like to use , the Rockford Fosgate Punch HE 10 RFP4410
200 Watts at 4ohm per sub
https://www.sonicelectronix.com/item_933_Rockford-Fosgate-HE-RFP4410-10-Punch-HE.html
this causing a slight issue, i've been told that i can wire up in the following manner
Option 1
Series 2 Subs taking the ohmage to 8ohms, and then parallel to the remainder 1 sub bringing the load down to 2.6 OHM, however, i hear that there are current issues and other bits that come with this
Option 2
Parallel all the subs down to 1,34 Ohms and hope for the best
Option 3
Run 2 Subs at 2 Ohms , and keep a spare 10" sub, though i really don't want to use this option
any thoughts and input would be great, i'm actually hoping someone has done an amp dyno on the above mentioned amp, and makes mention it does 1ohm safely (problem solved )
thanks guys
geepherder
Platinum - Posts: 3,668
Posted: June 07, 2019 at 5:49 PM / IP Logged Link to Post Post Reply Quote geepherder
If you're set on 3 subs, my advice is to find an amp that's meant to run at 1 ohm. Otherwise just run 2.
Sunday, March 1, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
