Air Bag Light, 2014 Nissan Frontier
gman619
Posted: June 15, 2019 at 4:04 AM / IP Logged Link to Post Post Reply Quote gman619
recently i installed a double din kenwood stereo into a 2014 nissan fronteer truck. real easy install. except now the air bag light stays lit up constantly. i used the propper factory to aftermarket wireing harness along with the antenna adapter it called for but cant figure out why this airbag light stays on now. any help or advice for me ???
Platinum - Posts: 13,725
Posted: June 15, 2019 at 11:58 AM / IP Logged Link to Post Post Reply Quote i am an idiot
You turned the key on with the airbag light unplugged. There is a procedure you can perform to clear the light. Give me a minute to find it.
Posted: June 15, 2019 at 12:00 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Is it flashing? If so, the following will help. I just noticed you said it stays on. If it is on solid you have other issues. If it is flashing, this will help.
https://www.the12volt.com/installbay/search.asp?kw=nissan+airbag&SM=1&SI=PTBA&FM=0&aid=199561&OB=1&Submit=Start+Search
Posted: June 15, 2019 at 12:42 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Actual link to the instructions so you do not have to search through the posts.
https://www.nissanforums.com/d40-2004-present/97692-resetting-05-frontier-airbag-light.html
Sunday, March 1, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
