2019 GMC Acadia with Bose, Subwoofer Install
jh1973
Copper - Posts: 50
Posted: April 09, 2020 at 10:08 PM / IP Logged Link to Post Post Reply Quote jh1973
2019 Acadia with Bose factory system. Looking at the diagram and stock Bose amp connector I don't know if I should tap the front door speakers or the stock subwoofer for a signal going to my mono amp. According to the diagram and at the Bose connector the front speaker wires are much thicker than the subwoofer wires so does that mean the front speakers are carrying the bass load more than the stock sub? Thanks for any feedback guys.
Rumors of Bob but never Bob......So what is it you tell people you do these days Bob?
eguru
Copper - Posts: 340
Posted: April 10, 2020 at 8:15 AM / IP Logged Link to Post Post Reply Quote eguru
Does your vehicle already have a separate amp for its subwoofer? Do you have ANC?
jh1973
Copper - Posts: 50
Posted: April 10, 2020 at 9:48 AM / IP Logged Link to Post Post Reply Quote jh1973
Yes,it has a Bose amp which I'm tapping for a signal. I have the ANC bypass harness already which disables the microphones to prevent that feedback from getting into the audio signal.
I just want to know if I should tap the front doors or stock subwoofer or maybe both?
Platinum - Posts: 13,725
Posted: April 11, 2020 at 6:48 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Subwoofer - With Amp      Blue/Gray - Gray/Black (premium)      +,-      Amplifier under front of center console, gray 8 pin plug, pins 1 - 5
jh1973
Copper - Posts: 50
Posted: April 11, 2020 at 7:35 PM / IP Logged Link to Post Post Reply Quote jh1973
I knew the colors, thanks though. My question was whether to tap the subwoofer or front doors because the sub wires are far skinnier than the front doors indicating less current passes through. Thoughts?
Posted: April 12, 2020 at 7:01 AM / IP Logged Link to Post Post Reply Quote i am an idiot
Have you listened to the factory sub to verify it is actually playing music? I have seen GM use a larger driver for only noise cancelling.
jh1973
Copper - Posts: 50
Posted: April 12, 2020 at 4:04 PM / IP Logged Link to Post Post Reply Quote jh1973
That's very true,I didn't think of that.
Saturday, February 28, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
