2003 Suzuki XL7, Amp Bypass
pogue _mahone
Posted: January 09, 2022 at 10:19 AM / IP Logged Link to Post Post Reply Quote pogue _mahone
I just installed a deck, there was no stereo in it when I got it. It sounds terrible, there is obviously a factory amp that's got to go. I was hoping there might be some wiring diagrams for the amp bypass. It would be nice to find something before I dig into this.
Anyone have any experience with vehicle?
Thanks in advance.
Platinum - Posts: 13,726
Posted: January 09, 2022 at 11:50 AM / IP Logged Link to Post Post Reply Quote i am an idiot
Radio 12V      white      +      radio harness
Radio Ground      black      -      radio harness
Radio Ignition      white/black      +      radio harness
Radio Illumination      violet/yellow (dimmer)      +      radio harness
Left Front Speaker (+/-)      brown/white - brown/black      +,-      radio harness
Right Front Speaker (+/-)      gray/green - gray/black      +,-      radio harness
Left Rear Speaker (+/-)      lt. green - lt. green/black      +,-      radio harness
Right Rear Speaker (+/-)      gray - gray/black      +,-      radio harness
directechs shows nothing about an amplifier
pogue _mahone
Posted: January 09, 2022 at 10:38 PM / IP Logged Link to Post Post Reply Quote pogue _mahone
Thanks. I couldn't find anything on an amp either. I'll have to ohm out the speaker circuits. It starts crackling and sounding terrible after about 15 minutes then after a little while it will stop making sound altogether. I thought it was the cheap Blaupunkt deck I had put in. I swapped it out for a less cheap Boss unit, same issue. It does have a factory sub.
Thursday, April 16, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
