No Power
smee
Posted: September 04, 2003 at 5:45 AM / IP Logged
Installing a new Kenwood head unit in a '93 Jeep Wrangler.  No power.  Checked fuses, hit reset switch.  Any ideas?
Smee
DYohn
Platinum - Posts: 10,741
Posted: September 04, 2003 at 7:10 AM / IP Logged
Wiring.  Constant power, ground and switched power.  Check these with a volt/ohm meter.
Platinum - Posts: 12,488
Posted: September 04, 2003 at 9:22 AM / IP Logged
Check the wiring behind the Kenwood deck. It is not inline rather built right into the back where the harness plugs into the deck.
smee
Posted: September 04, 2003 at 10:22 AM / IP Logged
Bought myself a low voltage tester.  The constant power is the culprit.  It is apparently the same circuit as the dome light, but the fuse is OK.  I can't seem to find a break in the line.  Any suggestions?  Thanks for the help so far.
Smee
mj239air
Copper - Posts: 153
Posted: September 04, 2003 at 10:26 AM / IP Logged
I would just run a new line directly to another constant 12 volt source. You can even go directly to the battery if you wanted, but you shouldn't need that. Should be able to find another constant source!
smee
Posted: September 04, 2003 at 10:30 AM / IP Logged
Thanks.  I may do that, and then I'll have to run down the dome light wiring because that isn't working either.
Smee
speedwayaudio1
Silver - Posts: 879
Posted: September 04, 2003 at 12:01 PM / IP Logged
make sure if you go staight for the batt to use a fuse. let's not burn our jeep down. lol
Big Dave
smee
Posted: September 05, 2003 at 7:05 AM / IP Logged
Figgered' it out!  In the power distribution center in the engine compartment, among the relays and the maxi fuses, are two 10 amp mini fuses.  One is for the horn, and the other is for the "ignition off draw ciruits".  (I got a clue after noticing the brake lights wouldn't work if the ignition was off.   Problem solved!
Now, if I could just get the @$%# speakers out of the dash of the jeep!
Smee
Saturday, May 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
