dumb enclosure question
JoejBlow
Posted: September 04, 2003 at 5:41 PM / IP Logged
K i just bought a set of woofers and box for my car nothing special it was kind of a kit thing that has 2 10" sub and came with a box (planning on replacing the subs when i can afford them)   now the box is ported and the front of the sub are enclosed with a plexi glass front with like 6" gap between the subs face and the plexiglass now the problem with this is that i don't exactly have the biggest trunk in the world and i use it for work and other things like putting skis or golf clubs in the trunk so i want to maximize the room  i have so i was wondering if i could cut off 4"-5" of that gap and seal it back  up again
now would doing that completely mess up the sound from the box or could i do it with out it effecting it too too much
as i said dumb question :):) :P
auex
Platinum - Posts: 5,041
Posted: September 04, 2003 at 5:59 PM / IP Logged
If the box is a bandpass box, don't cut it because it will ruin it. If you need room then build a sealed box that is easy to remove.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
c.c.
Member - Posts: 48
Posted: September 04, 2003 at 6:35 PM / IP Logged
dude...do yourself a favor, sell the box, buy some 3/4" mdf at home depot (maybe 10 bucks), some caulk and a tube of "carpenters goop".  then make a box that is around 1-1.25 cft for each sub, or for one box, make it like 2.5cft or so.  changing the dimensions of a box already built is tricky, and will ruin the box more than likely.  if anything, try carstereo.com for some box building ideas.  its got calculators and all.
toyota echo...perfect sound named vehicle
wvsquirrel
Gold - Posts: 1,237
Posted: September 05, 2003 at 12:33 AM / IP Logged
Yea, from the way you described it you bought a bandpass box. Cutting it down in size will ruin the box and it will sound like sh$t. Either buy or build a sealed enclosure, it will make your life a lot easier.
Squirrel
"No more Cpt. Kirk chit chat"
Donate to the12volt.com
