Capacitors
wayland1985
Silver - Posts: 353
Posted: March 12, 2004 at 11:39 PM / IP Logged
I will need a set of capacitors reaaaaaaaaal soon.  Has anybody used KnuKonceptz  brand capacitors?  ( www.knukonceptz.com).  If so, how are they?   How about Audiobahn Caps?  Any other suggestions, for a reasonable price?
I currently have all knukonceptz wires, and audiobahn components......and for some anal reason, I'd like to keep it down to 2-3 different brands in my car..... I dunno why, but I guess it's I just want a clean install, without using 30 different components.....
~wayland
DYohn
Moderator - Posts: 10,741
Posted: March 13, 2004 at 9:26 AM / IP Logged
Why do you think you need capacitors?
ravenndude
Silver - Posts: 250
Posted: March 13, 2004 at 6:32 PM / IP Logged
his light are probably dimming bad like mine Capacitors -- posted image. ) I was told that caps are caps and brands normally don't matter. Just remember the rule: 1 farad for 1000 watts. I've seen some cheap caps on e-bay ... like $70 for 2.2 farads
Ketel22
Silver - Posts: 976
Posted: March 13, 2004 at 6:44 PM / IP Logged
if its lights dimming get a new alt before you get a cap.
Quad L Handyman services
DYohn
Posted: March 13, 2004 at 6:48 PM / IP Logged
Exactly.  Caps are a waste of money if your system is putting too much load on your alternator.  Get a high-output alternator.
ravenndude
Silver - Posts: 250
Posted: March 13, 2004 at 6:51 PM / IP Logged
how much would a high-output alternator run? or does it depend on the car?
Ketel22
Silver - Posts: 976
Posted: March 13, 2004 at 6:54 PM / IP Logged
depends on the car and if you buy a new one or have yours rebuilt, i believe it can run $50 and up.
wayland1985
Silver - Posts: 353
Posted: March 13, 2004 at 11:30 PM / IP Logged
A high output alternator DEFINATLEY costs more than 50 bux...... you must of left out a "0".   I've seen them ranging from 400-1400.....depending on what kind you get.  Since I don't have 500 bucks to drop right away, I'm looking for a quick solution to a system that swallows power for breakfast (It's and amp putting out 1800 watts RMS at 1 ohm).  I just want the security that I'll have a little juice in reserve, should I hit a large note,  so that my truck wont shut off...
~wayland
Ketel22
Silver - Posts: 976
Posted: March 14, 2004 at 6:41 AM / IP Logged
maybe not $50 to buy a new highout put alt. but to rebuild the curret alt. you have is a different story. you can have to done for as low as $50 depending how much the shop is going to ripp you off.
Ravendarat
Platinum - Posts: 2,806
Posted: March 14, 2004 at 10:04 AM / IP Logged
I dunno, my lights flashed and I put in a cap, problem solved. I dont understand where you guys are getting the idea that they dont work, I know from experience they do. Now in his case he says he needs two or 3 caps. When you get in to that much power caps may not completly solve the problem and he may need a high output altenator but it wont hurt any thing to put them in, and in the end he is probally still gonna need them to properly power the system. Look at caps like superchargers. Superchargers run off a belt that attaches to the engine. The supercharger put more draw on the motor but is compansates by making way more power than what it consumes, a cap does the same thing but with voltage not with horse power. You can disagree with me if you want but I have enough experience with it to know what works what doesnt and caps will solve your problem probally 70-80 percent of the time
Wednesday, May 29, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
