Pulsing Sub
mnemesis
Posted: May 23, 2004 at 8:18 PM / IP Logged
I have a Pioneer DEHP4650 HU, JBL GTO4000 amp, factory fitted speakers, and a Pioneer 12" sub, this is in a Mitsubishi Magna. At the moment the sub is pulsating both randomly and sometimes on a regular beat, even with the volume control right down or on mute. I have adjusted the gain and the ground connection but it is still having fits every now and then. I was just wondering what could be the problem, and most importantly, how to fix it.
lspker
Silver - Posts: 503
Posted: May 23, 2004 at 8:54 PM / IP Logged
Sounds like you may have blowenthe grounds off your rca's (probably in the deck)  check by temporarily attaching a ground to the shield (outside) of rca at amp, if thumping goes away then find where and you the ground blew off.
NowYaKnow
Gold - Posts: 1,217
Posted: May 23, 2004 at 10:21 PM / IP Logged
As mentioned I would start by checking for bad rcas or a bad connection on the rcas.. Good luck,
Mike
