2003 Dodge Stratus wiring diagam ,etc.
kslamm
Posted: June 27, 2004 at 8:22 PM / IP Logged
Looking for a wiring diagram for a 2003 Dodge Stratus,any help would be gratly appreciated.Also anybody know  the best possible way to hook up the remote turn on from my amp?Was not sure if the factory 4 disc changer that are in the Stratus' have a wire to splice into or if I need another alternative?Thanks.
jfk51502003
Copper - Posts: 221
Posted: July 01, 2004 at 2:22 PM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - DODGE / STRATUS SEDAN / 2003 / Remote Start
[PRINT THIS PAGE]
12voltspink/black & red + ignition harness
Starteryellow + ignition harness
Second StarterN/A
Ignitionblue + ignition harness
Second IgnitionGREEN/ red (20 awg) + ignition harness
Third Ignition
AccessoryBLACK/ orange + ignition harness
Second AccessoryBLACK/ white + ignition harness
Keysense
Power LockWHITE/ green + conn. C4, pin 15 @ BCM
Notes: Lock requires a positive trigger thru a 1800 ohm resistor. Unlock requires a positive trigger thru a 750 ohm resistor. MUST use relays.
The BCM (Body Control Module) is attached to the fuse/relay box at the end of the dash on the driver side. Connector C4 is a 26 pin plug on the bottom edge of the BCM.
Power Unlocksame wire as power lock
Lock MotorORANGE / black 5wiconn. C4, pin 9 @ BCM
Notes: The BCM (Body Control Module) is attached to the fuse/relay box at the end of the dash on the driver side. Connector C4 is a 26 pin plug on the bottom edge of the BCM.
Unlock Motorblue/white 5wiconn. C4, pin 13 @ BCM
Parking Lights+BLACK / YELLOW + headlight switch or DKP
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger - conn. C4 @ BCM
Notes: The driver door trigger is tan in pin 5, the front passenger door is tan/red in pin 6, the left rear door is tan/orange in pin 7, and the right rear door is tan / YELLOW in pin 8. Use all four wires and diode isolate each.
Dome Supervisionuse door trigger
Trunk/Hatch Pintan/black - conn. C4, pin 18 @ BCM
Hood Pin
Trunk/Hatch ReleaseBLACK/ white 5wiconn. C4, pin 1 @ BCM
Power Sliding DoorN/A
Factory Alarm Armlt. GREEN/ orange + conn. C4, pin 4 @ BCM
Notes: Arm requires a positive trigger thru a 1800 ohm resistor. Disarm requires a positive trigger thru a 750 ohm resistor. MUST use relays.
Factory Alarm Disarmsame wire as alarm arm
Disarm No Unlocksee factory alarm disarm
TachometerNOT GREEN/ lt. green ac any ign. coil or fuel injector
Wait to startN/A
Brake WireWHITE/ tan + brake pedal switch
Parking Brake
Horn TriggerBLACK/ red - steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
2003 Dodge Stratus wiring diagam ,etc. -- posted image.
Immobilizer Bypass Module:Required: YesType: Sentry KeyPart #: 555C, 556U, or 555U
Notes: Only vehicles with gray keys have the immobilizer.
Thursday, March 12, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
