1989 oldsmobile, DEH-P6500
Pass the Roc
Copper - Posts: 51
Posted: August 08, 2004 at 6:30 PM / IP Logged
hey im trying to wire a pioneer deck into a 1989 oldsmobile, but the wires are all cut from the factory radio and do not have the original harness. so i cann'ot get a harness for it i have to hardwire it. can anyone help me with a colour diagram or tell me wich wires go with eachother to make this work
DYohn
Moderator - Posts: 10,741
Posted: August 08, 2004 at 6:34 PM / IP Logged
Click on "Vehicle Information" under General Info to the left.  Select 1989 and Oldsmobile then click on your car type on the link marked STEREO.  Good luck.
Pass the Roc
Copper - Posts: 51
Posted: August 08, 2004 at 8:15 PM / IP Logged
ok thanks
Pass the Roc
Copper - Posts: 51
Posted: August 08, 2004 at 9:35 PM / IP Logged
im trying to get the installation manual for my pioneer deck,  i am on the pioneer website but i get an error when i try to brng up any manual. so could someone please put the wire guide on here for me to see. the model is DEH-P6500
here is the link of the models
http://www.pioneerelectronics.com/pna/product/manual/0,,2076_4277,00.html
Ravendarat
Platinum - Posts: 2,806
Posted: August 09, 2004 at 12:00 AM / IP Logged
yellow = constant 12v
red = ignition
white = drivers side front speaker
grey = passanger side front speaker
green = drivers side rear speaker
purple = passanger side rear speaker
black = ground
ORANGE / white = dimmer
yellow/black = telephone mute
blue/white = amp remote
white, purple, green, grey wires with black traces are negative speaker wires where as those same colors with out the stripes are the positive speaker wires.
Pass the Roc
Copper - Posts: 51
Posted: August 09, 2004 at 12:56 PM / IP Logged
thanks alot
Pass the Roc
Copper - Posts: 51
Posted: August 09, 2004 at 1:10 PM / IP Logged
hello im trying to wire my pioneer deck in my oldsmobile. there is no harness so i have to hardwire them. im positive i have the right wires hooked up with eachother, constant to sonstant, switched to switched and so on. but yet when i turn the ignition on the deck does not turn on. There is a new battery in the car. I do not know what the problem is. I checked the constant wires with a volt metre. it is getting a pretty low reading. If anyone can help me or give me some tips in what to do or what you think i am  doing wrong let me know, thanks
kgerry
Platinum - Posts: 3,455
Posted: August 09, 2004 at 2:36 PM / IP Logged
make sure you didnt mix up the yellow, grey, brown or orange wires... there are two of each and they serve very different functions.... grab a meter and verify.....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Sunday, June 16, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
