amplifier bypass 1994 /1995 pathfinder
labtec
Posted: January 08, 2005 at 12:00 AM / IP Logged
Trying to install a pioneer mp3/cd player into a 1995 nissan pathfinder.
it is early 1995 so may be wired as a 1994
Factory deck is a Clarion model no. pn-9661h, part no. 286-7756-13
Speaker amp in rear passenger panel is model no. en-966n part no. 286-7062-58
And model no. en-998n part no. 286-7062-57
I got the deck wired up and everything it lights up but there is no sound.
I am wondering how to  bypass the speaker amps.
Is there any wiring diagrams for those amps
Any help would be appreciated.
labtec
Posted: January 08, 2005 at 12:13 AM / IP Logged
Trying to install a pioneer mp3/cd player into a 1995 nissan pathfinder. It is early 1995 so it may be wired as a 1994.
Factory deck is a Clarion model no. pn-9661h, part no 286-7756-13.
Speaker amp in rear passenger panel is model no. en-966n part no. 286-7062-58 and model no en-998n part no 286-7062-57
I got the deck wired up and the panel works ok but there is no sound.
is there any wiring diagrams for those amps
Any help would be appreciated./
Not sure why all the other crap got mixed up in the previous post. Might have happened when I pasted it in.
geepherder
Platinum - Posts: 3,668
Posted: January 08, 2005 at 10:13 PM / IP Logged
Have a look here to match up which plugs you have behing the deck, and hook it up accordingly.
http://www.installdr.com/Harnesses/Nissan-Wiring.pdf
labtec
Posted: January 09, 2005 at 1:11 AM / IP Logged
Thanks for the info. I got it figured out. had to use a battery to trace the wires back to the rear passenger side panel (where the two amps were located. Then I used a battery to locate the wires for the speakers. The front tweeters were 2.4 ohm and the larger speaker was 3.4 so I wired them in series. The rear speakers were already hooked together & they showed as 4 ohms each side combined. (didn't look to see how it was wired)
After all that. & doing it out in the cold. Works great.
Great forum here. I found a lot of useful info. Thanks.
Monday, March 2, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
