Voltage and amps
haemphyst
Platinum - Posts: 5,059
Posted: June 22, 2005 at 11:58 PM / IP Logged
Yes. The efficiency runs very low, which means they generate more heat than designed for, and can possibly blow devices in the power supply. If an item is designed to run on 14 violts, it needs 14 volts...
dwarren
Posted: June 23, 2005 at 12:00 AM / IP Logged
Why are you getting 10 volts or so at your amps? I believe it will put will put strain on them, yes.
If you are, your amps should be the least of your worries, the car's electrical system (brain included) are at risk!
Nodestiny
Copper - Posts: 85
Posted: June 23, 2005 at 8:12 AM / IP Logged
nah i wouldnt worry about it. Unless you run the amp on a constant 10V for several hours... GOOD amps should be able to run as low as 9V and as high as 18V without issues (unless you are running a very low ohm load, lower than what the manufacturer designed the amp for, then your amp may not last that long).
Most good amps have a thermal overload on it as well... do you know if yours does? What amp is it?
04 dodge neon SXT
(2) Oz Audio Matrix Elite 12"s sealed in 4 cube fiberglass enclosure, powered by HiFonics BX1605D
Oz Audio Matrix 180cs 6.5" component set power by HiFonics ZX4000
Friday, February 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
