dash speakers in old style 93 wrangler
BoominRolla
Copper - Posts: 198
Posted: June 27, 2005 at 11:33 AM / IP Logged
These speakers are MOUNTED TO THE STOCK METAL DASH!! WTF!?!? GREAT DESIGN THERE JEEP!!! How do I get them out? I've called everywhere and there like ohhh those are difficult... NO KIDDING I can't even get my hand up there when I remove all the torx bolts... What do you suggest removing the dash???
WBWisme
Posted: June 27, 2005 at 1:13 PM / IP Logged
 you will need a torx bit set. remove the end bolts from the outside of the dash and pry out on the dash a little. Not to much. It will go back when you put the bolts back. The speakers are held in with 8 mm nuts I think. Once they are loose just squeeze your hand up there. Enjoy the pain. I hope you do have A/C because then it is even more difficult.  Have fun dash speakers in old style 93 wrangler -- posted image.
BoominRolla
Copper - Posts: 198
Posted: June 29, 2005 at 10:04 AM / IP Logged
yeah thats what I figured it almost sounds easier to remove the entire dash... We had a guy like 2 years ago replace some in an older jeep but it took him awhile I could only pry the passangers side dash a few inches... then couldn't get up there to  get the right socket on the nuts on the back on the speaker... and on the drivers side you can't even reach the speaker from the bottom theres something in the way like a metal plate...
