Box design ?'s
sampsotr
Member - Posts: 11
Posted: June 27, 2005 at 11:26 PM / IP Logged
Hi, I just got a SPL of 138.3 at a local db drag and show and i'm wanting a box to boost my numbers in to the mid 140's that wold be enough to compete around here. I have talked to a lot of shops and I've gotten a few ideas that I need advice on. This is my box as is http://www.cardomain.com/ride/2015567/2
I want to keep the shape but make it taller and bigger at the base. I have a very nice hard hitting bass and I want to keep it. First the wood is 12" x 1"  thick black walnut for the new box, is this acceptable? Second....I thinking about ports that can be sealed off when not in use so I can get the sound when i'm not compeating. Can this be done? The new subs will be 15W3v2's after I get my setup sold off so im going to do a JL styling. I thought about ports that are shaped like the logos. I can get port volume with them but will they sound normal? Any help will be great.
customcarchris
Copper - Posts: 95
Posted: June 27, 2005 at 11:44 PM / IP Logged
Where are you getting that kind of black walnut and isn't it costing you major $$$?
dwarren
Posted: June 27, 2005 at 11:51 PM / IP Logged
I am not too keen on the idea of walnut. That is a very dense wood and is probably not suited for an acoustic application. Stick with MDF and apply some walnut veneer if you are in to the walnut look.
Second, the idea of switching between a sealed and ported box is not going to happen. The internal volume for a sealed box will be different from that of a ported box and it just won't happen. Either go ported or go sealed.
sampsotr
Member - Posts: 11
Posted: June 28, 2005 at 1:49 PM / IP Logged
The black walnut is from a tree that had to come down in our front yard so no charge besides the sawmill. Can this be used for the face at least? I want that dark real wood look. Also the port and sealed cubes are close enough  for JL specs.....4 cubes max sealed and 4 cubes min ported. If that isn't possable can I build a sealed box capable of mid 140's that plays my music just as well?
Thursday, March 19, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
