Newbie simple question
the_dark_()/\/3
Posted: June 28, 2005 at 7:02 AM / IP Logged
Hi all,
I know this is a noob question and i will prob get flamed to all hell for it, but I just need a yes or no answer for this question:
Is this amp http://www.pioneeraus.com.au/car_entertainment/amplifiers/gm5100t/index.html 2ohm stable?
ie) can I connect two 4ohm subwoofers, bridged, in parallel?
I am almost positive I can but because i'm new at this i would just like some reassurance
"May, call The Dark One"
joebiv318
Member - Posts: 46
Posted: June 28, 2005 at 8:16 AM / IP Logged
No you would need 8 ohm subs to do what you are thinking.
Two 4 ohm subs ran in parallel = 2 ohm.  So the amp bridged would be running at 1 ohm.
Two 8 ohm subs ran in parallel = 4 ohm. so the amp bridged would be running at 2 ohm.
Owner/ Custom Compact Performance
Treo,Cadence,ARC Audio
Critical Mass/Icon TV
Panasonic,Compustar,Scosche
Monday, February 2, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
