influencing what impedence the amp sees
mr_diggs
Posted: March 07, 2006 at 6:01 PM / IP Logged
Is if possible to manipulate what impedence the amplifier sees? My problem is that I plan on using some morel drivers and they are 8ohm, naturally i'd like the amp to see 4ohm in order to get some power out of it. I'll be using an xtant 404m. Im not sure if using a resistor in parallel would work or if that would just heat the crap outa the resistor. if anyone knows please reply.
derek
mr_diggs
Posted: March 07, 2006 at 6:27 PM / IP Logged
sorry for the searchless post, anyway I have thought about an impedance matching transformer with twice the windings on the speaker side making it a 1:2 ratio. This should fix my problem but low quality transformers have a tendancy to chop out some freq. maybe someone knows where to get high quality transformers??? or maybe I'll search this time:)
audiocableguy
Copper - Posts: 630
Posted: March 07, 2006 at 8:47 PM / IP Logged
Vertas made a matching x-former to change Imp up or down. Don't think they sold a huge amount. Morel makes some high end Car stuff that is 4 ohms. (Elate, Ovation)
The X-formers will also eat up amp power and turn it to heat. The power gain isn't worth it.
DYohn
Platinum - Posts: 10,741
Posted: March 08, 2006 at 11:33 AM / IP Logged
NO, transformers NOT are a good idea.  They will simply consume power and add distortion.  If you want to use 8-ohm speakers, use them.  The amp will be much happier.  The problem comes with too LOW an impedance, not too high.
forbidden
Platinum - Posts: 5,354
Posted: March 08, 2006 at 2:32 PM / IP Logged
Could always wire in another pair of identical speakers in parallel if space allows, in the case if it is a mid, it might be a win win situation.
Thursday, May 21, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
